Back to:
Tags:
Receivers
Generic problem for all Receivers
I have a denon AVR-2105 (by 2 users)
posted by bexmarshall on Mar 11, 2008
i have a denon AVR-2105 when i switch it on using the On/Standby button
which flashes RED it immediatly turns to a green flashing light and the system ignites only to be killed seconds later and the RED button flashes standby again, i have never had it working before as it was a recent gift.
is it a common problem or maybe needs a new switch, somebody else suggested a over heating problem but its not on for very long before it switches itself off
anyideas?
Thanks
Bex
thebexmarshall@yahoo.co.uk
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Damo2, posted on Mar 29, 2008
I've got exactly the same problem with my AVR-2105...as do a lot of people when you search the internet. Even if all cables (exept powercable) are disconected the problem still occurs.
A big thanks in advance for anyone who has the solution!
david.mous@pandora.be
Solution #1
posted on Aug 16, 2008
Not Rated (0)
Foxyjay
Rank:Apprentice Apprentice
Rating: 78%, 2 votes
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on i have a denon AVR-2105:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
my audio on my logitech web cam does not work when using...
Receivers
My Roalnd W-30 is describing a "Disk Load...
Receivers
so i've had some back luck trying to find a cooperative...
Receivers
I bought a JL Audio 500/1 Mono Block Amplifier off of Ebay...
Receivers
onky power board # 1B20950-1A
Loading problems.
Repair Service
Find Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
