Question about Fuji FinePix A345 Digital Camera
LCD SCREEN Hi my digital camera takes pictures quite fine but the problem is no images are displayed on the LCD screen. The Lcd screen is white. Can u tell me what is wrong
  • disneyraj Mar 31, 2008
    lcd monitor does not display any thing . please could you help
    rajesh
    Master:
  • 377 Answers
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
Posted on Mar 24, 2008
  • Anonymous Mar 24, 2008
    One way out of the glare is to use the optical viewfinder (if your camera has one) to preview your image instead of the LCD. Another possibility is to buy a camera that has a backlit LCD.
SOURCE:
I turned my camera on and the lcd screen is white and shows no image. I plugged it into my computer and the pictures are still intact, and the camera is able to take pictures, but I can not view them on...
Try restarting your camera a few times and see if that solves the problem. I would suggest saving all of your pictures and reset the camera if possible. Sony's quality of their cybershots are quite sub-par and common things like an LCD shorting out is quite frequent, so you may have to call the manufacturer to replace/repair your camera.
Mar 06, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
My screen on the camera is white how do i fix it?
Hi there its repairable. But your question not so clear. If the image come proper but the LCD screen is white then the problem occur in LCD screen. So just replaced the screen. But after click the snap if that's white or dark ( no image ) then your lens connection or lens only damaged. So please let me know the image is came or not. Both are repairable. Thanks & waiting for your feedback.
Apr 01, 2010 | Fuji FinePix A345 Digital Camera
Wont show image in the lcd display while taking photo?
Can you more clearly what you mean "while taking photo"?If lcd not display image...is that any text or symbol in the lcd?If you can still see the symbol or text in the lcd, I think you have trouble in your lens or ccd.
Trouble in the lens usually make the lcd display white screen. And, if ccd trouble the lcd display white horisontal line and if so hard broken the lcd display black screen, but the symbol or text is shown.
Sep 20, 2009 | Canon PowerShot A75 Digital Camera
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Cannon sd400 power shot
Sounds to me like you have a broken LCD screen. This is unfortunately very common in the SD200, SD300, and SD400 cameras. Because an LCD display is made up of a few sheets of very thin glass, they tend to break rather easil and then the "dye" leaks out, hence your feather pattern.
If you feel up to taking your camera apart, you can purchase a replacement screen on eBay for around $60-$80. If you don't feel up to trying to replace it yourself there are people on eBay who offer repair services for broken LCDs and they typically charge between $80-$100.
Apr 10, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
LCD White-out
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Sep 07, 2007 | Fuji FinePix A350 Digital Camera
LCD screen is white
Good Day, try taking pictures despite no display or LCD is white, connect to PC and observe, if the picture you took can be seen on PC, then your LCD display is defective, hope this will help, thanks
Aug 31, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Fuji FinePix A345 Digital Camera Logo
229 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
