Question about Nokia N73 Cellular Phone
CONNECTION TO HEADSET
I want to connect a handfree headset to my Nokia N73. Please tell me which file I must go in at the menu. I do not know where to pair the phone and headset.
    President:
  • 1,017 Answers
It should be under Menu/Connectivity/Bluetooth/Bluetooth select ON, then, My phone's visibility select Shown to all, then, My phone's name give it a name IE. Fred (you can change the name as often as you like).
There are two tabs where you are now, select the left one, go into Options select New paired device. Your phone will search for other devices, when it finds one you can pair the two, a pin number will be asked, keep things simple choose 0000 for both devices.
Posted on Mar 14, 2008
  • Raysagem
    Raysagem Mar 14, 2008
    Sorry you are in the left tab, select the right one.
Sir I buy bh-105 bluetooth for N73 But can not connect.
Please follow the below steps to connect your head set to mobile.
1. Ensure that your mobile device is switched on and the headset is off.
2. Press and hold the power key of headset for about 5 seconds until the green indicator light starts to flash quickly.
3.Activate Bluetooth connectivity on your mobile , and set it to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. If necessary, enter the passcode 0000 to pair and connect the
headset to your device.
When the headset is connected to your device and is ready for use, the green indicator light flashes about every 5 seconds.
Thank you
Aug 07, 2010 | Nokia N73 Cellular Phone
Sound volume is very low N73 ME Nokia
check your headset if it's original or test it with other headset.
Feb 18, 2010 | Nokia N73 Music Edition Smartphone
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
Aug 02, 2009 | Nokia N73 Cellular Phone
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
3. Activate the Bluetooth feature on the phone, and set the phone
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Enhancement not supported??
It is either Software or Hardware - both solutions below... best of luck
SOFTWARE
Just in case this setting got mixed up, go to menu - tools - settings - general - enhancement - and make sure your default is set to "Headset". If it is already set to "Headset" then it may be a hardware issue...
HARDWARE
The Nokia detects a 2.5mm jack when inserted and defaults to the standard headset mode (sound comes out through the headset but uses the phone speaker). There could be 2 causes to this (1) short in the headset jack or (2) debris in the headset jack that is making a connection between the contacts.
I recommend that you use a "can of air" sprayed directly in the jack to clear any debris. If this does not work, plug in the phone/headset jack that came with it and ensure that it detects it.
If that does not work, it is a short and you should return it or, if it is out of warranty, get someone skilled to replace or disable the jack (only do this is you have no other option -- Nokia won't touch it after you open and solder it).
Feb 09, 2009 | Nokia N73 Cellular Phone
Getting my head set to pair
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select your bluetooth (i dont know your bluetooth model no.) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Nov 09, 2008 | Motorola Mobility Bluetooth Hands Free...
Connection problem for Philips VOX130 with other bluetooth devices
4.Select VOX130 once a connection is detected.
Tips:
Jul 05, 2008 | Philips VOX130 Wireless Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Nokia N73 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
