Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Keeps turning off
Hello, My Dyson keeps turning off aftre about 10 mins, I have cleaned the filter all the pipes are clear. The motor unit gets very hot which is why I think it is doing this - please advise Thanks
    President:
  • 1,673 Answers
How is the suction at the hose? If low then you still have a clog which will cause the motor to overheat. Otherwise you may have a motor going bad.
Posted on Mar 20, 2008
SOURCE:
My Dyson V6 started suction and motor pulsated instead of staying on. Filter cleaned - nothing blocking wand....help
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 07, 2017 | Dyson Vacuums
How to order / replace motor exhaust foam filter?
Hi, it's Allie from Crucial Vacuum!
Maintaining your unit's filter clean and clog-free is crucial in keeping your unit working properly. Your Dyson DC39 has a washable and reusable pre-filter, part number 923413-01.
Washable filters are recommended to be washed after every 1 or 2 uses and replaced every 3 to 6 months, depending on the use of your unit.
First, make sure your unit is 'off' and unplugged. Remove the dust bin by pushing the button next to your unit's handle and remove the filter from the bin. Wash your filter under running lukewarm water until the water runs clear. Allow your filter to air dry for 24 hours before placing it back into your unit. Do not use any soaps or detergents and only dry your filter naturally. Placing your unit in a dishwasher and/or dryer may damage the filter.
Having a spare filter is a great idea to have while washing the unit's filter.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc39-pre-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dyson Vacuums
My vacum keeps sutting itsself off after a few mins of use. I need to vacum the whole house and dont have tinme for it to cool down every 10 mins
Something is plugged. What you describe sounds like the motors' thermal limiter is opening the circuit to prevent the motor from overheating. You need to open and verify that evey air passageway is clear and the unit has good air flow. I bet you find a blockage, and with one, cleaning ability would be severly diminshed.
Nov 19, 2010 | Dyson DC31 Animal Bagless Handheld...
Keeps turning itself off, have to wait 20 mins then it starts again. Is it a wiring problem?
the motor is likely getting too hot ... that will trip a thermal protection breaker .. when it cools after 20 minutes then it resets ... the motor gets hot when there is not enough air flow thru it ... you should check or replace all the filters in the machine .. there is a motor filter that you might be able to wash ... check for clogged passageways .. something is stopping air from flowing thru the motor .. usually its just the motor filter clogged ..
Jun 21, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson animal shuts of after 5-10 min of use
The "hidden" filter at the base of the unit is the HEPA filter, there is another filter on the side of the vacuum that you can remove and wash with water. Make sure that is washed out. If it's too dirty it will restrict air flow and the motor will overheat.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 keeps cutting out after few minutes
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dco7 quits running after 10 min I wait 15 min to start again
Jan 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Vacume cleaner trips on thermal after 10 min motor not excesive hot resets after 15 min has been doing this for the last 3 mths. Could it be faulty thermal or motor overheat how can I check...
first, check both filters on that unit. the premotor filter on the side, and the hepa filter underneath the canister. if those filters are clean move through the suction channel and look for a clog or obstruction. also make sure the canister is clean. I have never seen the thermal go bad on those machines (not saying it cant happen though). it sounds like the filters are dirty or you have a clog. its also a good idea to change the pre motor filter if its older than a yr. the foam is fine but the white material behind the foam gets clogged frequently. let me know if you have any other questions and if this doesnt fix the problem.
Jan 06, 2010 | Dyson DC07 All Floors Bagless Upright...
Got hot and turned off
getting too hot is a sign that the air flow is restricted ... that could be a clogged filter, hose or air intake ... there is a thermal breaker in the moter that will shut the machine off if it gets too hot .. it will automatically reset in 5-10 minutes ... but you have to fix the lack of air flow to keep it running ..
Sep 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
267 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
