Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips Magnavox projection TV
I believe I have a 2000 or 2001 model. Its a phillips Magnavox. Well, my husband got the thing for free cause the guy who owned it didnt want to put any money into fixing it. (well I dont want to either lol) Anyway...we turn it on and the tv looks fine except for it just looks like it needs alligned. We tried using the menu and alligning all the plus signs and stuff, but didnt seen to do any good. Its bowing in pretty good on the sides. Is there any way to fix this, and if so, around how much does something like that cost?
  • Scrambular Mar 14, 2008
    thank you so much! I will tell my husband and we will try that!
  • Philips Master
  • 8,617 Answers
You will need to change the convergence ICs both of them STK-392-120 they will cost about 15.00 each if you can solder you can do this repair yourself in a hour. A shop usually gets around 450 to do this repair. Let me know if you need further info.
Posted on Mar 11, 2008
  • Sonny Berry
    Sonny Berry Mar 14, 2008
    Just be sure to put some heat sink compound on the rear side of the new ICs where they contact the heat sink. This is available at radio shack comes in a small tube for 1.29 . Also check the resistors for signs of discoloration right next to the heatsink as often 1 or 2 of these will burn. They are easy to spot there are 6 or 7 of them all in the same area and they dont have any color bands that are on the other resistors. These are usually blue , green, or gray resistors.
I have a phillips ptv836 the power button lights up no pic or sound why
Check on the site www.tvrepairkits.com for your model. I believe its one of the oines that has a known shinking screen issue...when that issue surfaces one of the other possible symptoms is the TV will just shut down.
Feb 03, 2013 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
