Black/Green Distortion - Picture Quality - Wharfedale
I have a Wharfedale LCD 26 HDMI TV. After owning the TV for 18 months the picture quality on all channels has suddenly started to show all black/shaded areas as green distorted images, a kind of green fuzz. All other colours on the picture are fine. Peoples faces and bright colours are all perfect, just dark/black areas now replaced by this green distortion.
I have checked all connections/scarts, tried adjusting all picture quality settings such as brightness, contrast, sharpness etc. TV is running through Sky Digital box but other tv's in house are fine using same Sky connection.
Any ideas???
  • pazybien May 27, 2008
    I have the exact same problem on an Emprex 32" LCD TV. This problem has appeared in a few forums around the web but I have not yet found a single explanation.
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
Sam problem too :(
Picture quality and resolution
Try to download its user manual by internet. It has all details.
Jul 15, 2013 | RCA L32HD31 32 in. LCD HDTV
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
New Samsung LN40A550 LCD TV: picture is not crisp.
If you play with blu-Ray with HDMI, you will see the amazing picture quality.
I guaranty.
Jan 27, 2009 | Samsung LN40A550 LCD TV
How to change picture quality from 480 to 1080?
needs to be hooked to the tv with either an hdmi cable or componet(blue/green/red.yellow/white/) also check the game on the back of the box. some games are only made for 480 and 720
Jan 02, 2009 | Olevia LT37HV 37 in. HD-Ready LCD...
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Cables
HDMI cables are the best you can get right now as long as all your components have HDMI connections. Just don't overpay. Order them online and you'll be able to find them for less than $20 each. Walk into a store and you'll get jacked for $75 or more.
May 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Picture quality
I would suggest contacting Gateway for repairs if only 2 months old.
Feb 10, 2007 | Gateway LCD26TV 26 in. Television
Televison & Video Logo
578 people viewed this question
Top Televison & Video Experts
Electro Med Services...
