Question about Conair CID 502 Corded Phone
Handset Do you know where I can get a replacement handset for CID 502 model?
Decided the phone was not worth the money to invest
Posted on Mar 12, 2008
My Uniden Dect handset has stopped working. No dialtone. Also message on handset reads:'New CID:50'
CID(caller identification) your phone logs incoming calls in it's memory. The #30 signifies that there are 30 CID(phone #'s) logged in the memory of phone from callers. The phone saves the information for the last 50 received calls to the CID list. The NEW icon marks any calls received since the last time you checked the list. You can delete these one by one or all by pressing ID (CID# will come up) then press menu/select button I believe 3x and repeat until all unwanted CID's are deleted. page 9-10 of the Dect 6.0 manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button. https://www.101phones.com/content/pdf/un...
So your problem isn't related to that message. Disconnect your unit from the wall plug. Remove the handset battery, count to 10 and put it back. Plug the base unit in and try again. You need to check the line jack with a standard phone to make sure the line is good.
https://www.101phones.com/content/pdf/uniden/D1760.pdf
Dec 06, 2017 | Uniden Lands Phones
How do i delete cid on my uniden phone
For the D1680, D1480, and similar handsets:
Push the CID side of the four-way center switch
push [menu]
scroll to "Delete All"
push [select]
scroll to "Yes"
push [select] ( chirps ) push [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Feb 17, 2015 | Uniden Lands Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
What does New CID=1 mean?
CallerID. CID=1 mean there was one (new) caller ID number recorded by the telephone.
Hope it helps.
Sep 26, 2009 | Uniden 5.8GHz 2-handset with dual-keypad,...
Handset#1wont show caller id when the caller id button is pushed
Hardware issue, contact the maker of the phone if it's still under warranty to have them replace or repair it otherwise you might end up paying money for fixing the problem. Sounds like a metal contact is missing, something you can't fix on your own in most cases, even if it's worked in the past. Sorry to hear about your trouble, hope I helped out!
Mar 19, 2009 | Uniden 5.8GHz Cordless Phone
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Conair CID 502 Corded Phone Logo
41 people viewed this question
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
