Question about Sony KV-35S42 35" TV
Blinking screen i have a sony kv-35s42 35" tv, the screen blanks off for aprox. 1 ½ seconds and then back on in 3-4 second intervals and off again.
  • terrieno Dec 05, 2008
    Mine would blink for awhile then stay on but now it blinks all the time. Some channels it blinks faster then on other channels. Audio works fine
  • Anonymous Feb 18, 2009
    blinking picture when on. tube and sound ok. Started out 2 wks ago intermitent . now all the time
My Sont Trinitrtron is flashing off and on.
Posted on Jan 26, 2009
    Genius:
  • 1,694 Answers
Bad CRT...no repair.................................T.
Posted on Mar 20, 2008
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
KV32CS76E red light blinks 5 times again and again totaaly blank screen
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Feb 02, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I am repairing a sony TV KV-32FQ70E. The led blinks 5 times, stops and blinks again. Please tel me what means.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly, (G2 voltage).
Check the tube emmision, it may be too low to track, causing that error.
Hope that helps
Dec 14, 2010 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Sony KV-35S42 35" TV Logo
402 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
