Question about BOSE48 - Lifestyle 48 Home Entertainment System (black) Refurbished System
DVD is stuck in Bose lifestlye 48 media player
Hey
i cannot get the DVD to play. i also cannot get it out, the display says "opening" or "closing" depending on how many times i press the eject button but it does not do anything.
otherwisethe system is working well
  • 1 more comment
  • Anonymous Apr 04, 2008
    I'm having the same problem and my unit was new.
  • karen46 Apr 23, 2008
    hey i have same problem with cd ?
  • Mel47 Jun 07, 2008
    I too have a CD stuck in my Lifestyles 48. I called Tech Support and they said to pull the power input to totally power down the unit. Also press on the door to the tray slightly. None of that worked, so they said send it in and $165.00 could fix it. Seems unreasonable for a 2 year old unit. I expect better service considering the initial cost.
    Mel47
I had the same problem on lifestyle 38 series - got a DVD stuck. I tried shutting off the system for 1 min and then pushed eject - didn't work. Then I let the system standby for about 30 mins or so while drive was spinning for some reason. When the buzz stopped, I pushed eject button and disc popped out!!
Meanwhile I'd contacted bose customer support who wanted me to mail in the system for a repair fee of $150...?? I'd expect bose to put in little more quality in their "supposedly high end" systems. My other DVD player (a 40$ machine) drive never had this problem :-)
Posted on Dec 19, 2008
We had a power surge during a thunderstorm that dimmed our lights, and after that the CD opened as normal.
A friend suggested that I pull the power connector, press the open/close button and hold it down as I reconnected the power connector. The power surge beat me to that, so I don't know if it works. It was more than "Tech Support" could offer however.
Mel47
Posted on Jun 18, 2008
Dvd stuck in open/close tray bose lifestyle 48 system
open it up and take out the dvd then it will work
Jul 23, 2010 | Bose Lifestyle 48 System
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Televison & Video
My Bose lifesystem 48 will not start when i start it up error 802 is showing in the display. I can her some nois (tikking) from the harddisk. i am from Norway but my Bose is from USA .I use a transformer...
Purchase a new bose mk4025gas hard drive from impact computers .com for 100 bucks and install, a monkey can take six scews out, pull back up and slide off top remove hard drive from the side of the dvd player, just pull out remove 2 screws from bottom and then pull off ribbon. install back in reverse order.
Dec 22, 2009 | Bose Lifestyle 48 System
DVD Format Problem in Bose LS 48
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
Jul 27, 2009 | Bose Lifestyle 48 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Bose Lifestlye 48 DVD Plays only in Black & White, was working properly till now. Please assist.
Check on the remote if got a video sistem function maybe are on the wrong sistem
Oct 20, 2008 | Bose Lifestyle 48 System
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
DVD frozen
suggest unplug Bose system from the wall for 10 secs, then plug in and allow it to initialise.
if this fails take bose unit to dealer.
Aug 17, 2007 | Bose Lifestyle 48 System
BOSE48 - Lifestyle 48 Home Entertainment System (black) Refurbished System Logo
280 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
