You can get the code for free from a dealership if it was in the vehicle as new. Of you pay a radio code finder company. The manual refers to your Blaupunkt Passport.
Enter the code number given in the Blaupunkt car radio passport and confirm: See example "Restart following interruption ...". The code system is now deactivated.
If you have disconnected your battery or you have lost your car radio code and your radio is asking you the unlock code, instant-radio-code.com is the official ...
PDF
Boston CC 22 ... Buttons 1-4: Use to enter a code num- ber. Press each ... code to be found in the car radio pass- ... Before starting to use your new car radio you.
The resetting code for your car radio should be with the owner's manual and other documentation that came with your car. The instructions for resetting the radio will be in the owner's manual.
If you don't happen to have that, then, you will need to contact an automobile dealership which sells your make of car.
When you find the code or obtain one from a dealership, I suggest you do what I have done: write the code inside your owner's manual on the page with the instructions for resetting the radio, so you will be able to reset the radio again, whenever needed. Note: When the car battery is replaced will be another time you will have to reset the radio.
If the code is not at the back of your manual, try 0000 and if the radio locked it self from taking any more codes. Just disconnect the battery and that will reset the radio so you can re-enter the code. If 0000 did not work then log on to Radio-code.com, you can get your cod there for like $12.00 which is cheaper then the dealer and you get to know the codes as most dealer will just unlock the radio. Good luck and hope this helps, keep me posted if you have any more question.
IF RADIO CODE STICKER IS NOT ON OF GLOVE BOX LID YOU WILL NEED TO REMOVE RADIO (AND THEN SOMETIMES CODE STICKER IS ON BOTTOM SIDE OF RADIO)IF NOTYOU WILL NEED TO RT DOWN S/N OF RADIO(ON TOP OF RADIO) TAKE S/N TO HONDA DEALER AND THEY CAN GET CODE FOR YOU FROM S/N. GOOD LUCK
