Question about Epson Stylus Photo R300 InkJet Printer
Printer appears to be printing normally but only blank sheets coming out!
I have just changed the cyan ink on my printer, pressed print and all sounded normal except when I went to get the printout all the sheets were blank. How can I sort this out please!
    Guru:
  • 377 Answers
Hi dear
try to resetting your catridge
or here
http://inkjetprinterhelp.us/epsonSSC.html
oke
i hope your problem clear
good luck
Posted on Mar 26, 2008
SOURCE:
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
    Do the following to clean the print head:
    1. Press INK key on the control panel.
    2. Press the DOWN arrow key until CLEANING appears on the LCD.
    3. Press OK.
    4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
    5. Press OK.
    The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
    If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
    Do the following to print a Print Quality Check Sheet:
    1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
    2. Press OK. PRINT QUALITY will appear on the LCD.
    3. Press OK.
    4. Press COLOR START.
    NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
    Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
    Mfc 5860 red printing green - already checked print levels. all are fine.
    1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
    a. Press INK.
    b. Press the UP OR DOWN ARROW key to select Test Print.
    c. Press OK.
    d. Use the UP OR DOWN ARROW key to select Print Quality.
    e. Press OK.
    f. Press COLOR START
    The machine will generate the Print Quality Check Sheet.
    2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
    a. Press STOP/EXIT to return to the "Date and Time" display.
    3. Evaluate the Print Quality Check Sheet.
    On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    NOTE: Cyan is the light blue color and magenta is the pinkish color.
    a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
    4. Open the Ink Refill cover.
    5. Open the cartridge covers of the colors that do not appear in the correct order.
    6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
    7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
    a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
    b. Press 7-6, The LCD will display CLEANING ALL
    c. Press 6, the LCD will display eINIT__P ALL
    d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
    e. Press the BLACK START Key.
    • After the machine completes the Setup Purge it will return to the Standby Display.
    8. Print another Print Quality Check Sheet
    a. Press INK.
    c. Press OK.
    e. Press OK.
    9. The machine will generate another Print Quality Check Sheet.
    a. If all four colors printed correctly the issue is resolved.
    b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
    Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
    WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
    This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
    NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
    To resolve this issue you will need to clean the print head.
    NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
    1. First verify the position of the ink cartridges:
    a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
    b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
    - If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
    - If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
    Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
    When all the cartridges are installed, close the ink cartridge cover.
    2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
    1. Press the INK key.
    2. Press OK to select Test Print.
    3. Press OK to select Print Quality.
    4. Press the COLOR START key.
    5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
    a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
    b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
    6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
    a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
    d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
    NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
    e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
    If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
    NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
    7. Test by printing the document that had the reported problem (wrong color printing).
    Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
    Blue (CYAN) not printing despite changing ink tank
    enough ink b ut not printing at all - blank paper on every time despite noise as if printing
    Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
    Won't Print Yellow Ink
    your yellow colour is used mostly please refil your colour cartridge or change your colour cartridge.
    Jul 30, 2009 | Epson Stylus C44UX InkJet Printer
    Lines in the print
    Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
    Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
    Printer will not print after reinstall of software to macbook
    yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
    to determine the status of the ink..
    goto your desktop ..
    click the printer driver software and select ink status..
    good luck.
    May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
    PRINTING BLANK SHEETS
    You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
    Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
    Photo printing
    It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
    2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
    3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
    I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
    So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
    Oct 25, 2006 | Canon I900D InkJet Photo Printer
    Epson Stylus Photo R300 InkJet Printer Logo
    109 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
