Dual Soud card issue
I wanted to know if I can have the output of my 1st could card looped into the input of my 2nd sound card.
  • 19,396 Answers
On windows you cannot direct sound out to more than one device at the time, unless you use particular devices (external audio devices etc.) therefore it is impossible to do this
regards
Posted on Mar 11, 2008
SOURCE:
I have a Peavey XR-600 PA Head, I would like to know if and how can I connect a MX 200 Dual Reverb Effects Processor to the PA Head?
If it has a effects loop output and input on the p.a. head and a in and out on the reverb effects processor, then yes you can, just run the effects loop output signal into the input on your reverb processor, out of the output back into the input effects loop on the p.a. head, kinda like you would a effects pedal thru the effects loop of a guitar amplifier. hope this helps!
Dec 02, 2015 | Peavey Music
No soud on my hp
Put some soud on it (whatever that is).
May 20, 2015 | HP Computers & Internet
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
Jun 11, 2014 | Marantz NR-1604 7.1 channel HT receiver...
How do I hook up my velodyne 8 in speaker to my Sony receiver and how do I hook up my receiver to my Kenwood 7030 equalizer
1st, does the Sony have a dedicated subwoofer connection on the rear panel? 2nd, EQ's normally go in the INPUT and OUTPUT loops of a stereo receiver like your Sony. For example, a tape (or preamp) OUTPUT connects to the EQ's INPUT and the EQ's OUTPUT connects to your Sony's INPUT (tape IN or power amp IN). Remember...all outs feed in's and all in's feed outs.
May 31, 2014 | Audio Players & Recorders
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Ringing sound in background
sounds like there is a input to output loop of some kind. On some of my soundcards I was able to configure a virtual patchbay. Check around in the software for this and macke sure outputs are to outputs and ins to ins. Good luck.
Aug 28, 2009 | Rane Serato Scratch Live Computer DJ...
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
