How can I change the brightness & resolution on my NEW acer x193w monitor? The instruction booklett is verv unspecific! I am alsi finding that certain programmes are responding a lot slower than ever before. I have a DELL 4300 with only 1/8th of ysed space on my hard drive. Please advise OR advise ne who I need to ask about this problem? My old (very old) monitor gave me none of these problems. Thank you, Your fastest reply would be appreciated very much. Tim Edmunds. timedmunds@sky.com.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
Basically its work on a resolution of 1440x900 install drivers for lcd monitor and set the brightness and contrast in display properties(advanced) again same problem post clearly the problem
Posted on Mar 11, 2008
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
I go to screen resolution but the thing is the resolution is greyed out. please help Acer X193w
You need to install the latest drivers for your graphics card, so your computer can run at a higher resolution.
Nvidia Graphics Driver for Nvidia made Graphics Card.
AMD Graphics Driver for AMD Radeon made Graphics Card.
Select your Graphics Card model and Operating System.
Download and install.
Note: Only use the drivers provided for your make and model of graphics card!!!
Thanking you
damnor01
Feb 02, 2011 | Acer X193W LCD Monitor
What is the recomended resolution display setting for my Acer X193w monitor
A computer monitor is made of pixels (short for "picture element").
Monitor resolution is measured in pixels, width by height. 640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, an aspect ratio of 4:3. With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), all aspect ratios are the same.
Hope this initial information helps. Let me hear from you again for any clarifications.
Thank you for using fixya.com
Feb 23, 2010 | Acer X193W LCD Monitor
What should my screen resolution be
The maximum resolution for the Acer X193W LCD Monitor is 1440 x 90, which is a really good resolution range. It will depend also on what kind of graphics/video card and motherboard your computer has which can help determine if you can use the Acer at that maximum resolution.
Jan 26, 2010 | Acer X193W LCD Monitor
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
Acer x193w on win xp woulnt go above 800x600 resolution
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within it display range and 1440x900 is definitely within that range.
Dec 16, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
