Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox WorkCenter C2424
System Engine error 08,005.48
If I switch of the machine for over 6 hours, then it will start up again normally.
Some engineer told me the gears have become weak and the motor unit would need to be replaced.
I want a second opinion.
Also, a frank statement as to whether this is an inherent problem of all solid ink printers - as I plan to buy another solid ink printer only, but don't want to end up with two devices dying on me at the same time!
  • 1 more comment
  • dberz Mar 14, 2008
    Thanks for the help.
    The authorized Xerox Service engineer came and took out one rod which had two plastic fixtures on either end and said it looks damaged due to wear and tear (machine is barely 2 yrs old with only 50,000 prints) and will replace it once the spare arrives from Xerox.
    Meantime, I was wondering where can I get the work center C2424 service manual pdf file.
    tia
  • dberz Mar 15, 2008
    Thanks. I really appreciate all the help. my email id is [email protected]
    thanks again.
    Thanks for all the help. I really appreciate it. My email id is [email protected]
    Thanks again
  • 25 Answers
Hi Tryit,
From reading your detailled descriptions of the numerous problems it's possible to have and to cure with this printer, I reckon I've got a sticky print head block. I'm getting System Error 07,010.43:8651.
I changed the maintenance kit when it first happened but it was too late. The old kit was caked in horrible residues and some had clearly spilt into the printer's innards. I'd love to have your thoughts on how best to get inside the machine and clean it. I have tried to open it up but it didn't prove easy so I put it back together again and rang Xerox, who were conspicuously vague and unhelpful, although they were very prompt in sending a vastly expensive estimate for an engineer to come and replace the "print engine" (is there such a thing?).
If you still have a copy of the manual pdf, could you send me a copy please? matt at mousemusic dot co dot uk.
Thank you very much indeed,
Matt
Posted on Jul 01, 2009
  • mousemusic Jul 01, 2009
    Oops! Sorry - I posted my problem as a solution! I'm just a newbie here and I'm still figuring out what all these buttons do. Please forgive me...
Now I've stumbled upon a similar issue with my Workcentere 2424.
At first I was just receiving paper jam codes, but after looking through it, and determining a no paper jams, I then started receiving a 07 code error.
I have since replaced the maintenance kit, cleaned the excess ink tray, installed ink, wiped out the maintenance kit housing cavity, ran many a system test, and reset the NVRAM.
Would anyone be able to help me resolve this issue?
  • Whether through PDF Manual -so I can properly get inside & clean, etc..
  • IF I should be performing any specific functionality tests, in specific orders etc..
My email is [email protected]
Posted on Sep 17, 2008
    President:
  • 2,072 Answers
8,000.xx Errors - Cap/Wipe Sub-system Faults
8,000.6x Errors - Program Faults
For 8,000.6x errors, try the following:
a. Reset NVRAM, and retest.
b. Ensure ground integrity for the system (see "Ensuring Ground Integrity" on
page 4-70).
8,000.4x - 8,055.4x Troubleshooting Procedures
Step Questions and Actions Yes No
1 1.
Run the Wiper Drive test.
2. Did the test pass?
Go to Step 2. Go to Step 3.
2 1. Run the Wiper Alignment test.
Go to Step 4. Go to Step 3.
3 1. Inspect the wiper system for improper
operation, obstructions, or damage (broken
gear or belt).
2. Ensure the wiper system is properly aligned
(see "Wiper Alignment" on page 6-2). Also,
see "Homing the Printhead Wiper" on
page 6-4.
3. Did this correct the problem?
Complete. Go to Step 5.
4 1. Run the Head Maintenance Clutch test.
Go to Step 6. Go to Step 5.
5 1. Is the head lock mechanism on the right end
of the MEP assembly is functioning
properly?
Go to Step 6. Replace the
exit assembly.
6 1. Are there obstructions or spilled ink in the
media path?
Clean the inside
of the system
and retest.
Replace the
exit assembly
Posted on Mar 11, 2008
  • 2 more comments
  • Rick Kasper Mar 11, 2008
    After looking through the 08 codes and tests, I don't see a motor or gears referenced.
    Looking through this what is obviously happening is the wiper is not operating properly. Can you look in your fault files and see if there are any 07,xxx.xxx codes?
    If there are that would narrow it down a little more.With what you are saying, that you shut it down for a few hours it runs well makes me strongly suspect the Matainence Clutch is failing. That would make a lot of sence.
    The other thing I can think of is some ink being spillled into the print head pivot block causing the wiper to not have enough room to move up and down. The wiper referenced cleans the drum between pages.
    I am asking if you have any 07 codes, which would more indicate to me that the print head block is sticky.
    If so I can tell you how to remedy that.
    And in general, the solid ink printers are exceptionally reliable. Exceptionally. The most frequent problem I do see is what I am relating the print head block winds up with some of the ink in it and causes problems. But that is a very easy fix.
    Suspect the Head Maintenance Clutch. I would give a probability of 80 percent or more, that the clutch is slipping.
  • Rick Kasper Mar 14, 2008
    Send me your E-mail address.
    SOunds like the maintenance kit lift
  • Rick Kasper Mar 15, 2008
    I can send you a pdf file for the manual.
2 Suggested Answers
SOURCE:
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Xerox WorkCentre C2424: turned on, runs thru tests, initializing and then shuts off and starts the cycle again. The cycle continues but never resolves.
1. Power machine off and wait until completely off. 2. unplug power cord from wall. 3. with power cord STILL DISCONNECTED turn machine on and off again. 4. WAIT 60 SECONDS 5. plug power cord back in and turn back on
If this does not resolve the issue call for service.
Hope it helps!
Feb 09, 2011 | Xerox C2424 Copier
Xerox c2424 has error message "Waste Tray Missing". Have emptied waste tray which was overflowing and placed it back in machine but above error message means it will not work.
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Sep 10, 2010 | Xerox C2424 Copier
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
Workcentre C2424 System Error
That sounds like a problem with what is called the process drive motor. It is the assembly that moves the maintenance kit up and down to clean the drum.
It is located on the front right side of the machine and has a multi gear assembly to it.
It can be mistimed, there are 2 holes and an arrow on the bottom that must be aligned.
For service, to save money. you can contact a service dealer or an ASP in your area that would charge you far less than Xerox. If you don;t know who those service providers are, just let me know what your zip code is and I can look up the nearest ones for you.
May 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
756 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
