Question about Hitachi (900204) 100 GB Hard Drive
Hard disk data recovery
I have a hard disk in an encloser and it fell on the floor after that it start ticking but not starting , I search the internet for solution and all came to the same result the reading head is damage any way to recover my data ?
please reply asap
  • arj179 Oct 12, 2008
    I have 120 Gb Hitachi Hdd it has not undergone any shocks either but suddenly stopped working one fine day since april,
    the data recovery guys say that i need to give them a Hdd with same config wt do i do it is opened once i am myself an electronics guy.
    So can i do the changes on my own replacing the old hdd integrals with a new one.
  • Hitachi Master
  • 19,396 Answers
In effect the reading head is almost for sure damaged and there is no easy DIY way to recovery data at home.
If the content is really important you can send it to a company who does data recovery. Service is expensive and probably it is going to cost over $1000, furthermore they do not guarantee success.
This company does hard disk data recovery
Alternatively you can ask to a local repair shop to take a chance , get an Hard disk of same model and replace the disk. I warn you that chance of success working in this last way are very scarce and there is good possibilities that you lose your data forever
regards
Posted on Mar 11, 2008
SOURCE:
Just clicks when turned on
what sort of click ?
where is it coming from internally ?
Gently tap the hard drive with an opened hand and see if you can get it to spin up one last time. click start control panel administrative tools computer management disk management if you can see your drive right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive I found that you get best results by ticking one box then returning after it has finished then tick the other box Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. http://www.easeus.com/resource/hard-disk-data-recovery.htm Some addition links found on Google
http://www.datarecoveryreview.net/
Of course it can be sent to a data recovey company if you really have to get the data off.
Feb 02, 2013 | Western Digital My Book Essential Edition...
Can I copy d partition from a bad hard drive that tested for 10 min before bad hard drive showed up in test
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now, start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
for USB drives click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
then try copting your d partition
There are also Data Recovery programs that might be very helpful to recover your important information.
if you need more help with this post a reply
Hope this helps
Nov 06, 2012 | Computers & Internet
Dropped my Transcend Storejet25p 5oo gb on floor !
Your hard drive is damaged beyond repair.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 18, 2012 | Transcend StoreJet Computers & Internet
I have Memorex Ultra Traveldrive - 160GB USB Hard Drive. I dropped it by accident and now I can't get information stored in it. Please help!!
1 what happens when you plug it in ?
2 can you see it in disk management ?
3 does it make any noises when plugged in ?
hope this helps
Oct 12, 2012 | Memorex Ultra Traveldrive - 160GB USB Hard...
hope this helps
I lost data,hard disk is correpted
Kernel for Windows Data Recovery is one such effective data recovery tool that has got the capability e of recovering and restoring files/folders lost after accidental deletion, virus attack or any other kind of logical error to access the data. In fact, the software makes a proper use of recovery algorithm that helps in restoring every single bit of lost information. Besides this, the tool is also very much capable of retrieving data even when MFT is damaged. Visit http://www.recoveryfiles.net for more information.
Jul 16, 2012 | SanDisk Sansa e250 MP3 Player
Retrieve Hard Drive Data External Hard Drive
click start right click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors then select check now
start should schedule this task when restart if this is the hard drive with your operating system on it
i have found the best results ticking one box and wait until its finished then return and tick the other box
also
there are many freeware data recovery programs available on the internet and many pay data recovery programs
http://download.cnet.com/easeus-data-recovery-wizard/3000-2248_4-75184619.html
http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html
Mar 26, 2012 | Computers & Internet
HI please I really need help! I was using my LaCie hard disk one day and then the HD started doing a weird sound (tick-tick). Now every time the pc is on and i plug in the hard disk it does the ticking...
your drive suffered a head crash and the only way to get the data from it now is with a Data recovery center. If you do not need the data and your drive is under warranty, contact LaCie to get a replacement.
Regards,
Jan 09, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My Cavalry hard disk fell off from a couple of feet and now when i connect to the sys and power it on, it starts giving a wierd sound ..but the computer wont recognise the device.. is there a way to...
It does sound like you have the "click of death"
You could try remove the drive from its enclosure and connect it direct to a computer. If however it still clicks ticks or whines badly the it is probably toast.
You can however buy just a drive and put it in the enclosure. then maybe use crazy glue to hold it down.
A far as recovery goes then if it does not work on your computer directly then the other options is very expensive data recovery services
Aug 11, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Mar 11, 2008 | Konica Revio C2 Digital Camera
Open Questions:
See all Hitachi (900204) 100 GB Hard Drive Questions
Hitachi (900204) 100 GB Hard Drive Logo
144 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
