Denon AVR-4308 Wi-Fi connection I wonder if you can help? I have spent many hours trying to connect the amp using the Wi-Fi board to Internet Radio. It's a simple connect with the Ethernet cable to my Netgear Router and i can stream Internet Radio with ease, but not so easy using wi-fi.. I have followed the manuals instructions and everything happens the way it should, settings and such and the GUI states connection complete. then i go to the Internet Radio function with wi-fi established and it just blank screens and stays that way. Any ideas?
  • 796 Answers
Hello
Posted on Mar 11, 2008
  • isaac johny
    isaac johny Mar 11, 2008
    is there any indications of that the radio is connected ti wi-fi??
  • isaac johny
    also try to reset the settings in your radio to be default
I connected the phone to my wifi. But it wont go to any websites or mail etc.
Hi Shiela
Try the following as sometimes it's a simple setting missed..
Solution-1
On your phone under Settings>> WiFi >> Hold the Name of Your Network >> Now Click on Forgot Network.
Now reboot the phone & modem/router and try to connect the Wi-Fi again.
Solution-2
Pull out the phone battery while it is working & re-install after 30 second. Phone will reboot again now try to connect to network and check internet connectivity.
Solution-3
You can browse to Settings>> WiFi >> then press left menu key & Click on Advanced. Now check that Wi-Fi timer is not off. If Wi-Fi Timer is on then turn it off.
Now disable Wi-Fi & again enable it. Now check the connectivity on Android.
Solution -4 (Important)
Update your phone, Modem& Wi-Fi Router time and date to match the internet provider time and date. This is very important because 2 out of 10 cases are because of this issue.
Solution-5
Check the Internet connectivity after disabling the antivirus & mobile data.
May 01, 2016 | Cell Phones
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
My polaroid tablet model a7 will not authenticate and allow me to go on internet using wi-fi
Try it with a different router. Use a friends. Your router may have to be adjusted.
Go on the manufacturers web site and see if your problem is listed.
Jan 08, 2015 | Polaroid Tablets & eReaders
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I cant get an internet connection on this phone, do i need to set it up manually?
There are two ways you can connect to the internet over your phone. You can purchase a data plan from a company like AT&T which you can use anywhere. The other option would be to use your phone to connect to a wireless access point(WI-FI).
What are the differences? Wi-fi is usually free unless at a cofee shop etc but has a smaller area in which you can access(you have to be within a certain distance of the wireless router). A data plan cost money and is typically slower, however, you can use it at anytime as long as you have a signal on your phone.
You can click here to access the user guide for your phone.
If you have a data plan purchased and are using the SIM card they gave you then whenever you use a application on your phone that requires internet access it will connect.
If you go to page 83 of the manual it will go over the steps you need to take to enable Wi-Fi. In short, first active Wi-Fi
1) In Idle mode, open the application list and select Settings
? Wireless and network ? Wi-Fi settings ? Wi-Fi.
1) Then under Wi-Fi settings click Wi-Fi networks, select the Network you wish to connect to then click Connect.
Reference the user manual as it goes into more details about the features on your phone and how to use them.
Regards,
G33k
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
No surround back channel - damage during transport
I think your receiver has cracked main (amplifier) board close to surround back channel terminals. Need to take apart the receiver remove the board, inspect it and resolder cracked traces. Unfortunately it is not so easy to remove that board and probably you need to bring it to a repair shop.
May 18, 2009 | Denon AVR-4308CI Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
PS3 -Connect to Internet using PC with wireless Broadband Card???
Yes you can but you need a router or ou need to connect the ps3 directly to your lan card the just set up a shared internet connection through windows
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
252 people viewed this question
 Grubhead
Grubhead
