Problem w/ Philips Plasma TV
Good Day! I have a problem w/ my Philips Plasma TV model 42PF5520D/10. The Unit has no picture but there's still a sound. What could be be the possible problem? Iis there an available spareparts for this kind of problem? Thank you very much in advance.
  • heidijo5050 Sep 02, 2008
    The bottom half of my 42"plasma keeps going black every few hours. If I shut it off it will go away for awhile. I called phililps awhile ago and they didnt have a clue...anyone out there that can help?
  • pridh Dec 20, 2008
    i also have aflat tv model42pf5520d/10 the sound is working ,but no picture ,but if i turn the power on and off at the plug the picture flashes up for a second and then goes
Salir de memu
y programacion
Posted on Apr 04, 2008
Went to turn on tv from the side button and loud zap noise and bad smell coming out!
you horizontal output transformer inside the unit has a high voltage leak.
if you know how to open the back cover. you can try to clean the dust buildup
inside and in the back of the tube check the unit if still produce bad smell.
if still zapping replace your high voltage transformer it may have a leak.
Aug 26, 2011 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Hi. I have a 42PF5520D Philips 42" Plasma. Started
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
May 06, 2011 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Wont come on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Mar 21, 2010 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Picture comes on for split second
Hi.
Are you sure this is not on somthing like hide screen mode?
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Philips 42 in. Plasma TV
Philips 42 42pf5520d faulty
Hi, the power supply board has a little board towards the connectors. This board has an led and it will blink if there is an error, check how many blinks there are and then check on the on the power PCB next to this little board you will see the error explanation. Also check capacitors on the power board next to the control board connector, replace any bulging ones. I hope this helps.
Feb 01, 2010 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Plasma philips model 42pf5520d/10 working few seconds and go for stand by led
I have seen this once before and the reason was a capacitor on power supply board.
My bet would be Power Supply board, before we troubleshoot anything else. Check the continuity of the board. There might be many capacitors or diodes. Check the voltage across them. Sometimes, you can find a faulty capacitor by naked eye. Usually, the defective one are swelled.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Philips Televison & Video
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Picture takes a long time to come on
Need more info on the unit.
Model, Serial # and Version # on side of unit. It sounds like you either have powersupply problems or cold solder joints in the power supply. Resoldering board may solve your problems.
Let me know, Have a good day. Jay
Jan 20, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
