Dead amp Bought a diy krell ksa 150,after cleaning i have now put it together but it turns of after a couple of seconds.Have very strange readings over the caps in the powersupply.Where did i mess up you think!!!! Kindly/Ingemar
  • 1 more comment
  • ingemar johansson Mar 11, 2008
    Hi robotek.
    I hope you understand my"swenglish"As i told ,the amp turns off after just 5 sec.But i tried to take a measurment over the terminals on the caps its supposed to be 63v dc but ive got 15 on one of them and some very strange readings on the other ones.The voltage from the transformers seems to be ok at 48 ac.Where do you think i messed up?
    Kindly/Ingemar
  • ingemar johansson Mar 13, 2008
    Hi Graeme.I have been looking my self for a circuit but its a well hidden krell secret:).Yesterday i tried to just connect left and right chanels without using the psu caps and it works out with the right chanel but when i hook up the left one as well it is turning of after approx 15 sec!!
    Thanks for helping out!!!!
    Regards/Ingemar
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi there, can you tel me a bit more about the problem you are having... what strange readings are you getting
    regards
    Graeme
  • 1,512 Answers
Hi Ingemar... sorry for the delay getting back to you. It sounds like you may have a problem with transformer connections, or maybe orientation of a bridge rectifier. Check all connections in the power supply with particular attention to these. Check also that th3e caps are fitted the correct way around. Look also for hairline fractures in the PCB about the power supply. I am trying to find a circuit for your model at the mo. Not having much luck...do you have one you can link me to or upload to FixYa? Would get me on the same page as you to really get into the problem.
regards
Graeme
Posted on Mar 13, 2008
  • Graeme Ross
    Graeme Ross Mar 13, 2008
    found an old post on an audio forum about the problem you have... have you updated to Sprague P/s caps...
    check the DC offset at the output of the amp. If you have a problem here, the power supply may well sag, check for failed output transistors if that's the case.
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output.
Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps.
Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
Sep 09, 2016 | Krell Audio Players & Recorders
Hi, my Krell KSA 150amp is running cool any suggestions as to why. Many thanks
Audio output section circuit draws enormous current at idle stage. Contact any service electrician to detect the fault and get it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 31, 2014 | Krell Audio Players & Recorders
Doesnt wanna start
After gas sits in the gas tank & carbeurator(s) for a long period of time. it turns into varnish, stinks like hell. you will need to remove your carb(s), and take them completely apart. clean out all the jets, clean out the choke also. put it all back together, with some fresh gasoline, and you'll be good to go bro......
Mar 12, 2013 | Motorcycles
I have a 79 ford 460 big block an I just bought new alternator starter an battery an it keeps goin dead an not starting any diagrams or advice out there it would really be appreciated
Check ALL Ground Cables & Make Sure All Is Cleaned & Mounted Tightly. Then Check Terminal Connections & Loose Wire & Gage Of Wire. If It Ain't That?. You Need ta TEST Everything you Just Bought.
Apr 29, 2012 | 1981 Ford F 150
Convert to 220v krell amplifier ksa-250
if it is conertable to 120v there will be a tap on the transformer input for that
May 13, 2010 | Audio Players & Recorders
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Wiring Diagram required
At this point you may have fried the output stage. Is there a specific model listed on the back? I need that to locate the schematic.
Thanks,
Dan
Sep 29, 2008 | Krell Home Theater Standard 7.1...
177 people viewed this question
 Grubhead
Grubhead
