Question about Cameras
CASIO QV3000EX WILL NOT PLAY OR RECORD SOMTIMES SAYS FORMAT MEMORY CARD AND WHEN I DO THIS IT ASKS ME TO FORMAT IT AGAIN
  • 1,512 Answers
Hi Hastens
Sounds like the memory card has developed a fault. You will need to replace it. Good luck, thanks for using FixYa
regards
Graeme
Posted on Mar 11, 2008
6ya staff
SOURCE:
I can not get phone to play audio recordings it keeps saying memory card empty when it is not audio is in mp3 format
It's possible that the phone can't read mp3 format. Convert your audio recording to a .WAV format and try again.
Aug 04, 2015 | Lands Phones
MUSIC I MOVED FROM COMPUTER TO SD CARD WILL NOT PLAY ON CELVIANO AP620 PIANO
http://support.casio.com/pdf/008/AP620_6_E_1A_web.pdf
E-48
Using a Memory Card
You can use the procedure below to play back a user
song (page E-24) stored on
a memory card without
loading the song into Digital Piano memory.
Memory Card Folders
Formatting a memory card on the Digital Piano will
automatically create the four
folders shown below. You
put playback song data into any one of the folders. You
can use the four folders to group your music data by
family member, genre, or some other categories. Use
buttons
through (folders) to select a folder.
1.Store the music data you want to play back in
one of the memory card folders.
2.Insert the memory ca
rd into the Digital
Piano's memory card slot.
3.Press the (CARD/INTERNAL) button.
4.Press one of the folder selection buttons (
through
) to select the card folder you want.
This will display the song number and song
name of the first song in the folder you
selected.
5.Use the (w,q) buttons to select the
song you want.
6.Press the (PLAY/STOP
) button.This will start playback.
•Each press of (PLAY/STOP) starts and stops
playback.
•Fast forward, fast reverse,
tempo changes, and other
operations are the same as
those during playback of a
user song in Digital Pian
o memory. For details, see
"Playing Back a Specific
Music Library Song" (page
E-24).
7.
To quit memory card data playback, press the
Dec 07, 2013 | Casio Celviano AP-620 88-Key Digital Piano...
Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
On some cameras, once you use the internal memory, you must format it and completely erase it before a regular memory card will work. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, never use the internal memory again.
Feb 17, 2011 | Intova CP9 Digital Camera
I've deleted all my files. But when I try to record something new it says "memory full".
Try to format the memory, if the device support formatting function, use this tools. But if there aren't any formatting tools, you can format your memory card via PC.
Put off your memory card and format it (you sure there is no file anymore, do you?).
After formatting complete, put in your memory card in your recorder again.
I hope you can record something again.
Hope this help and if you feel helped RATE please.
Jan 23, 2011 | Olympus WS-110 Digital Voice Recorder
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Aug 29, 2010 | Jazz Cameras
After I take a photo my camera says it's "busy, please wait" for about 10 seconds. I bought and formatted a new SD 4 GB card and it stopped doing that, so I thought it was good. After about a week, it...
I was having the same problem and contacted Casio. The issue seems to be that there are pictures/video on your internal camera memory which is conflicting with the memory card. Here is the fix:
Turn of the camera and take out your memory card Turn on the camera, click menu, setup, hit the up circle twice and click reset and click reset again until the camera resets
Then click menu again, setup, hit the up circle twice and click format, click format again until the camera formats
(This will delete the pictures from your memory card so make sure you have them saved) Turn off the camera and put your memory card back in, turn the camera on again. Repeat the format process for your memory card and you will be good to go!
Nov 02, 2009 | Casio Exilim EX-S12 Digital Camera
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
EX-S880 Shutdown
First off make sure that the battery when charging is a solid red light and NOT flashing. If it's flashing that means we have a problem with the battery.
Make sure you are only using a Toshiba, Panasonic or Sandisc memory card that is no larger than 1 GB unless you did a firmware upgrade to handle a larger card.
Take your memory card out. Turn the camera on and press menu, go over to setup, go down to format (this will format anything on the internal memory of camera) and press right arrow to highlight format and then press ok button. It will say busy please wait and then once that's done please press menu again, go to setup, go down to reset, press right arrow, highlight reset and press ok.
If the camera is still acting up after doing this please contact Casio repairs and they can fix it for an electrical issue.
Apr 27, 2008 | Casio Exilim EX-S880 Digital Camera
Card read error
Make sure it's a Sandisc, Toshiba, or Panasonic memory card. No bigger than 2 MB unless you have done a firmware upgrade. Try formatting memory card and if that doesn't work then you will have to get a different memory card.
Nov 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Formatting SD card
Possibly either- or Take it back to the shop and ask them to check by inserting another card or card into another camera Get which ever it is play up replaced
Sep 04, 2007 | Vivitar ViviCam 3730 Digital Camera
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
