Question about JVC HXD7 5-disc Home Stereo Theater System DVD changer Shelf System
Two issues with this system
(1) cd disc drawers do not respond to buttons..ie..will not open..dvd red signal lights seem to flash randomly
(2) no lcd display.l totally black..seems as if power disconnected from lcd unit?
any suggestions apprecaited!
all other aspects pf receiver work fine
found a piece of black plastic inside receiver..about 2" long/very narrow..looks like maybe paert of some transport system?
  • sshull66 May 08, 2009
    Disc door will not open, no responce from any of the buttons or remote, it does light up.
  • 1,512 Answers
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
regards
Graeme
Posted on Mar 11, 2008
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Dell Vostro 1310 - when turned on screen still blank, numlock blinking, capslock and scroll lock light on and stable. tried changed new RAM,issue still persist. whats wrong with it?
it may be bios problem or loose connection with Hard disc... So, follow the below steps: 1.remove the battery and power adapter 2.press the power on button 2 minutes 3.replace the battery 4.now on the laptop normally... now see the result.... ---------------------------------------------------------- if not solved then follow the below steps
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then problem with ur hard disc or cd/dvd drive.
------------------------------------------------------ follow the below steps to check the problem with your hard disc or cd/dvd drive
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 6.connect the cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive. ---------------------------------------------------
Apr 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
My DVD player has worked excellently for almost 10 years. Uncertain if that's the problem. All the buttons on the remote and on the front panel seem to respond--one way or another. This is a Sony CD/D
by a new player i recomend sony,there still the best. dont waste your money on blue ray,they will be obsolete in five years and they are very slow,ie. loading and reading discs, i know i sell them
May 19, 2009 | Televison & Video
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
174 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
