Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Lost setting for external fax
Old Biltong on Mar 11, 2008
Hi, I'm not too sure if this is your field but I cannot find anyone to assist me with a problem I have, and being a senior citizen I have had no formal IT training . So, if this is not something you handle I apologize in advance for bothering you. Background: My OS is Windows XP. I use ADSL for Internet access. The DSL router I have does not have faxing facilities. I fairly often need to send faxes so I downloaded and registered Snappy Fax V4.When I discovered from my service provider, Telkomsa.net, that my router does not support faxing, I coupled an external fax, US Robotics Sportster Flash 56 K , to my PC. This fax modem works well with Snappy Fax and I am able to send faxes. However, and this is my problem: each time I shut down my PC I loose the setting for the fax. To overcome this problem I have to disconnect the fax modem, shutdown the PC, reboot, reconnect the fax, go to the control panel and select "Phone & Modem", this then searches for the fax and once it finds the US Robotics fax modem I can go to Snappy Fax this then identifies that my fax modem is the US Robotics and I can then proceed to send a fax. As you can imagine, from the above, it is most frustrating to send a fax. I have written to Microsoft and Snappy Fax about my problem but have had no reply from either of them, hence me contacting you. What I want to know is why the setting is not retained when I shut down my PC and is there a means of overcoming this and how to go about it?. If you can possibly help me I would be most grateful. Kind regards Hilton Ward
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Related Problems
Unistall does not work but my computer thinks winfax is...
every time I open winfax pro10. it changes my desktop...
MY PROGRAM WORKED FINE FOR 10 MONTHS THEN 2 WEEKS AGO I...
I'm using dial-up internet connection and trying to install...
We cannot send attachments to a fax for the first time. We...
Can you Help with these Modem problems?
map sensor for 1993 honda civic ex...
Solve
map sensor for 1993 honda civic ex what is it purpose in the car
After installing my USR 5699B modem,...
Solve
After installing my USR 5699B modem, the cursor became eratic and jerky. I disabled the modem and... (More)
US Robotic modems will not pick up.
Solve
The USRobottics modems we have are not picking up when we try dialing to them. I used to have the... (More)
auto answer
Solve
I have my external 56k robotics modem hooked up to aan analog line. When I cal the number the modem... (More)
Winfax pro
Solve
every time I open winfax pro10. it changes my desktop display, it maximizes the Icons
Sponsored Links
Describe your Computer problem:
Top Modem Experts
Rank: Guru Guru
Solutions: 273
Experience: 35+ years as a computer technician, motorcycle racer, photographer, imaging consultant, tinkerer.
Ask Me
Find more Modem Experts
Top Computers & Laptop Repair
(330) 502-6853
Instead of lugging your computer into a shop and...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
jr electronics
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
