FixYa.com
Tags:
Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 (No buttons work and won't turn...
posted by Stuart T on Mar 11, 2008
Starting with an empty camera. I put an SD card in, then fitted fully charged Ni Mh batteries ( this has been tried with lithium ion and Mallory cells too).
The camera was switched on in (setup mode), the screen lights up (coolpix opening image), the lens stays in, no controls work and the camera won't switch off. I remove the batteries and the green light naturally goes out.
I did the same procedure in Scene mode. Similar happened, but the difference was that the lens went out of the body as normal. Still nothing else worked and when I took the batteries out the lens did not retract.
I then re shut the battery compartment door and the lens immediately retracted.
I turn on again and we go through the same cycle from the top of this page.
The last operation with the camera was to download to the computer, but after decoupling from the computer lead, I switched the camera on again, re formatted the card, turned the camera off and removed and replaced the card with a different card.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Digital Cameras problems?
date and time printed on pics
I have a Fuji FinePix F470 (it... Answer This...
Kodak high performance memory...
I have taken a bunch of... Answer This...
Terribly short battery life all...
Ive mostly used those green and... Answer This...
Nikon e4600 wont download...
When I try to download pictures... Answer This...
Downloading pictures from Nikon...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
