Toshiba 2GB USB Flash Drive Capacity Problem
I have a Toshibs 2GB USB Flash Drive I use on my Vista laptop. I have formatted the drive which shows a 1.85GB capacity remaining however will not allow me to put any more than 450MB in data before telling me the drive is full and preventing me from transferring any more files. At this point the drive properties stll show the remaining 1.5GB as free space however I can not transfer any more files. How can I access the remaining 1.5GB?
  • Bootsy76 Mar 11, 2008
    Thanks for the tip. I have tried doing yhis but Vista tells me my drive does not need defragmenting after formatting and I am still only able to transfer around 450MB before I get error messages on all files beyond this point (Error 0x80070052 File cannot be created)...any ideas from here?
I have toshiba flash drive and when i transfer some files to it..and after i had transfer the files and when i open it again the files are gone only folders left..what should i do?
Posted on Jun 09, 2010
Well, your flashdrive is originally formatted with FAT16(FAT) type. You can reformatted it using FAT32 from WinXP formatting tools. Just select the FAT type from the format windows/tap, and there goes, under FAT32 format, you can store any data to the maximum capacity. acerolas@gmail.com
Posted on Jun 13, 2009
Check under file properties and make sure view hidden is turned on for your drive. then look and see if your Trash bin is creating a recovery file.
I had this happen on one of my flash drives and it took forever to figure it out.
Posted on Mar 14, 2008
  • 38 Answers
Format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Posted on Mar 11, 2008
Toshiba 16gb flash drive is recognized by the computer but not by my printer
Are you sure that your printer is able to use such high capacity memory flash drives? You did not mention printer board and type.
a. Use FAT32 format and retry.
b. Use a smaller capacity flash drive.
Dec 14, 2016 | Toshiba Electronics - Others
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
Nov 06, 2013 | Computers & Internet
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
Jun 13, 2011 | Kingston 2GB Secure Digital Memory Card
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
Apr 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My capacity genx 2gb usb chenge to 14 mb.when i connect flash disk i show cd drive added in my computer and capacity my flash disk cheng of 2 gb to 14 mb.plz help.my email shaab.a@nisoc.ir
This typically means the drive has gone bad. Try reformatting the USB drive. Some manufacturers also provide diagnostic/formatting tools on their website that might be able to fix it. But likely it will need replaced. Lucky 2GB USB drives now only run $7.99 or less.
Apr 20, 2010 | Computers & Internet
RAW FS TO FAT 32
i recently bought a sony flash drive SSK/2GB.however the same is not working at all as it is showing RAW file system instead of FAT 32 .neither it is getting formatted nor allowing anything else to b doneto it.
Nov 11, 2007 | Electronics - Others
Computers & Internet Logo
839 people viewed this question
Alun Cox
David Payne
David Payne
