Question about ASUS P5RD1-VM Motherboard
Faulty time settings
Thanks for the help and advise..but the problem is that i already change the mboard battery twice...all set up is made at cmos time setting (f1 & save or f10) it set the time and save..also many tried to make new OS to set a regional time..but i got the same problem...need some advice again....
thanks experts
hamlet
  • Manis2008 Jun 23, 2008
    Yes I have same CMOS Battery Fix
    ing
  • sheri_rulezz Apr 09, 2009
    when i set any boot seting or time in board it sets but when i turn it off and turn it on after switching of the problem again comes
  • 73 Answers
Hi mayfield,
1)the problem is that cmos cell is not getting fixed or it is not touching the silverportion
2) just go to bios change date & time & save it will work
3) last option just remove all cable(hdd,cdrom,floppy,graphic card)& insert again than see it will work
4) if not than go the nearest shop & show him
Regards
shailesh
Posted on Mar 11, 2008
6ya staff
SOURCE:
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Cmos setting not saved
Look at the CMOS reset jumper, located near the battery:
For normal operation there should be a cap shorting pins 1 and 2.
Set the jumper correctly, make sure it really shorts these two pins (once I've seen a jumper cap that didn't have the metal connector inside, only plastic), replace the battery and it should keep the CMOS settings.
Dec 19, 2009 | ASUS P5PE-VM Motherboard
CMOS checksum bad
Check your battery connections sometimes when you change battery the connectors get distorted and do not connect properly.
Also check all M/board power conections
Nov 04, 2008 | EliteGroup P4M800PRO-M Motherboard
CMOS Checksum error.
the only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
Jul 14, 2008 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
CMOS BATTERY ERROR
You said that you already bought a new cmos bat, but still theres a problem.check the cmos battery socket,power on tyour pc and go to cmos setup,optimize default setting and set time and date.
May 27, 2008 | Computers & Internet
Hi melnavz,
Hello Mayfield.
Since that your computer is still booting. the processor, memory is good. The only problem you encountered is cannot hold the time when you totally unplug the unit to the wall. iN that case, maybe something wrong with your mboard. maybe there some connection or jumper that was unnoticeally remove which make the battery open circuit. Please refer to the manual of the maboard for some jumper setting.
melnavz
Mar 14, 2008 | ASUS P5RD1-VM Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Faulty time???
Hello!
That's the first time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
may this help!
Mar 03, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
131 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
