Question about ASUS P4S533 Motherboard
The board will not power up.
Only the LED is lit!
All of the fans, cdrom, Hd are not on.
I am running P4 2.4ghz with a PC2700 1G DDR meemory!
  • mlegend Mar 11, 2008
    Hmmm!
    I thought I had connected it correctly. I will recheck!
  • 73 Answers
Hi mlegend,
u have not properly attach the led in hdd,cdrom,pwsupply,reset for that u have a manual when u had purchased the motherboard in manual it would show u in whichparts led should be connected if u had the manual than try it by urself if not than just take ur motherboard to the nearest shop of computer & tell him to connect the led (hdd,cdrometc) if u try to connect it due to inconnection ur motherboard IC would be burn
regards
shailesh
Posted on Mar 11, 2008
My acer netbbook wont come on the power light is litt
Mother board or memory module can be the problem. First remove the cmos battery and switch on, if its ok then reinstall the cmos battery and see.check with other memory module or if you have 2 modules one at a time. If problem persists, try heating the motherboard display chipset with a blower, if you are a hardware technician. This should be done by only a professional as u can damage the motherboard and other parts. Last resort is replace mother board.
Sep 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Screen black out, but the cpu fan is running.
it could be two reasons.
1. your RAM has a issue ( try a different ram from a friends pc)
2. your Graphics card is having an issue. ( try removing & fixing back on, if it does notwork.. either get a friends graphics card & ifix on to your pc & chk or fix your VGA card on to another PC & chk if the VGA card works. either way you will find out what wrong.
let me know the out come.
hope it works
cheers..
Mar 19, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Fan comes on, no HD activity, no display
Go to the HP website and see if your machine is one of the many that compaq and hp are having those kind of issues with.My wife just had to send her machine in for a system board repalcement. They are offering a free one time fix for certain problems. Yours sounds like the same on my wife had. It took about 21/2 weeks from initial contact with tech support to fed ex dropping off fixed machine. Hope this helps. If it does please rate this answer.
Feb 04, 2009 | HP Pavilion dv2000t Notebook
Motherboard problems
Sorry for the delay in help. If you haven't gotten your pc running yet i suggest you check the cpu. It sounds like it is over heating.
Sep 04, 2008 | Computers & Internet
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ASUS P4S533 Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
