Back to:
Tags:
GE Profile JGS968 Gas Kitchen Range
Oven won't light, burners and broiler work
posted by mdh_11 on Mar 11, 2008
I saw a previous post, that you indicated the glow plug is the issue, I would like to learn how to replace mine. Can you please post instructuions on how to change this out. My range is a JGS968
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 11, 2008
FixYa! (100)
jsrock516
Rank:Guru Guru
Rating: 94%, 2113 votes
Here ya go...
The same method applies to both the broiler and bake manifold:
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting ***** holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
NOTE: Most igniters cost around $50. Prices will vary with models. I hope this is the information you needed.
Comment by jsrock516, posted on Mar 11, 2008
PS The five asterisks in Step 6, should read "s c r e w". The website is having problems associated with an automatic text checker. It should be corrected soon.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Oven won't light, burners and broiler work:
I don't want to Accept this solution
Solution #2
posted on Apr 14, 2008
Not Rated (0)
ilshak01
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The replacement igniter does not have the factory connectors. Does it make any difference which way the wires are connected to the old harness and connectors when using the supplied replacement ceramic wire nuts?
Thank You!
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
the pilot ignition doesn't light
Kitchen Ranges
2 large electric hot plate are always on high, the name on...
Ok, I know not to use the stove as this surprised and...
My oven resets after the temperature has climbed over 200...
Can I use the probe while in the convection bake mode?
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
