Back to:
Tags:
Epson Perfection 4870 PRO Flatbed Scanner
Epson 4870 ccd failure
posted by HughP on Mar 11, 2008
Suddenly the transparency scanner has stopped working with no light showing and producing black stripey images. Epson say contact local dealer as it is out of warranty. Local dealers say "We only deal with warranty claims". Help, neither could offer any help whatsoever. Can one actually replace/repair this item ?
Comment by HughP, posted on Apr 01, 2008
Thanks. I have now found a servicer able to repair (the nearest two did not do scanner repairs). But the passcode you suggested for the loyalty site does not work!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 31, 2008
Helpful (85)
Basti
Rank:Wiz Wiz
Rating: 83%, 392 votes
yes you can either send it to an epson certified servicer or check this site www.epson.com/loyalty and use this passcode LIZARD
Comment by Basti, posted on Apr 02, 2008
try leopard i will give you updates for this code
Rating Locked! (?) HughP has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Epson 4870 ccd failure:
I don't want to Accept this solution
Can you Help with these Scanners problems?
Scanners
I have found the drivers for the Minolta SC110 scanner for...
Scanners
I bought a used Uniden hand held scanner it is a newer...
Scanners
I have epson perfection photp 3490 pc, can i used on a...
I am trying to scan a color negative that fits perfectly...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
