2007 razr v3m can make calls but display screen white always and no outer display..keypad works and sounds work help !!
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
