Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Problem in opening cd.
I m trying to open any cd, but it dosent open,
even its not showing in "My Computer"
might be my driver is not working.
    Sergeant:
  • 349 Answers
That is certainly the most likely reason,it is broke ,you will need to replace the drive
as their is nothing you can do to repair it,
good luck
Terry
Posted on Mar 11, 2008
    Sergeant:
    Champion:
  • 244 Answers
Please checked in bios, is your dvd detected ?
if your dvd isnot detected, most of the time is your dvd, sometime it mainboard problem.
Also checked in the device manager, is your dvd there and need driver ?
if yes, you have 2 option, you can reload your OS or you can edit the registry.
follow this step if you want to edit the windows registry:
http://support.microsoft.com/kb/314060
How to open cd drive of a Acer aspire e 15
Hi
I would suggest that you load My Computer and in the left hand pane where it shows the drives, right click on the CD drive letter and in the menu that appears, click on "eject" and the draw should open.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 01, 2015 | Acer Aspire Computers & Internet
Gateway gp7-750 >both of my
Do this:
http://support.microsoft.com/kb/982116
Apr 04, 2011 | Gateway Computers & Internet
I put in a cd and it now wont recognize the drive at all. i can't get the disc out, no idea how to fix it
Hi Laurenleighd
Have a look at your CD/DVD drive and you will see a small pin hole that about the size of a needle. You can take a straightened paperclip and push it in there to open the CD dirve manualy. After you've removed it, try another CD that you know is working and see if you have the same problem. If this CD also get stuck in there then we know the CD/DVD ROM may be faulty.
Is this a Dell Laptop or Desktop?
Can you open and close the Drive with or without anything inside it?
Can you hear any noise coming from CD/DVD ROM when you insert a CD?
What Happens when you insert any other CDs or DVDs that you know is working fine?
When you open your MY Computer/Computer in the Start Menu, Can you see the drive there, or is it not showing the CD dirve there at all?
If the you are 100% sure this is not a power issue, then it might be the CD/DVD driver that needs to be re-installed.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Hope this helps
Jan 31, 2011 | Dell Computers & Internet
The DVD RW/CD-RW'S DRIVER is not working
CHeck the Device Manager. Does the CD/DVD Drive show up in Device manager, and when you right click it and choose properties, does it give any error code, like Error code 39?
Normally the CD drives use the default Windows drivers. Try right clicking the HL-DT-ST DVDRAM GSA T50N ATA Device in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error, it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Apr 11, 2009 | HP Compaq Presario SR1420nx...
Cannot open cd-rom drive!
The thing about cd/dvd drives in general is that they die and thats the case here even if you deleted anything of the operating system its self would notice that the cd drive was missing the driver and ask you about it since you havent stated that its safe to say that the drive is dead
Mar 13, 2009 | IBM ThinkPad T60 Notebook
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
DVD DRIVE WORKS, BUT CD DRIVE DEAD
Try using the manual eject that is as small as a pinhole just below or beside the CD drive. Once you find out that you can manually eject you may be able to insert a cleaning cd to clean the device.
If that doesn't work check device manager to see if it has the proper driver or if it's recognized that it's installed in the system.
Jul 16, 2008 | HP Desktop Computers - Hewlett-Packard...
My widows xp explorer dosent open
your windows installer was corrupted that why its asking open with , so if you windows xp cd which came with your laptop insert the cd and while installing it will show repair option(2 times it show 2nd time u click R) it will repair the operating system and your installer will back ** data will corrupt everything will be safe
Mar 09, 2008 | HP Pavilion dv6000z Notebook
Connection problem with Computer
ya.
first reinstall the camera software. if it dosent work there s some problem in your Operating system. try these. if it dosent work. please inform me
Dec 08, 2007 | Canon PowerShot A550 Digital Camera
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
57 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
