Question about HP ScanJet 2400 Flatbed Scanner
Default in laser covering
Dears Sirs,
when I launch a preview the laser covers only the first 4cm of the document and then stops with a bad noise...
what is wrong?
do you think I could mend it by opening the box and check the cables inside?
I dont know how to open it actually...
Thanks for your time.
Elise Dodelin
  • Anonymous Mar 23, 2008
    While scanning only top half of A4 sized page is scanned and in the remaining page only 'garbage' comes but last 2 or 3 lines of the same page are scanned again. No poblem with the drive, it fully covers the whole page. When I approched the company's service center they asked me to change the scanner. This can be told even by a lay man or a child . We should be given the causes which caused this problem and then asked to change which I assume , would be good to attarct more customers.
    asomarajan@gmail.com
    New Friend:
  • 159 Answers
If you don't have any idea how to open it don't do that and let any technical see it to you
Posted on Mar 12, 2008
Error 5B00 Canon Pixma MG6120 Printer
1. Turn off your color printer
2. Press and have the STOP/RESET button
3. Press and also hold Power ON key
4. While keeping the Power ON switch, discharge the STOP/RESET key
5. While holding still the Electrical power ON button, push two times the STOP/RESET switch
6. Launch the Power ON key
7. Wait until that show an "abandoned" information. It will definitely take about a moment.
8. When "still" appear, open the best cover to leave open the ink cartridges
9. Raise the cover for cartridge holder and also obtain both the and shade containers.
10. Gain the cover from container holder and switch off the printer
11. Gain the leading cover and also switch on the color printer again
12. After the laser printer activate, return the ink cartridges.
1. Push and also Have the STOP/RESET switch and stand by until this personal reboot.
2. Release the STOP/RESET switch the printer is actually restarting.
3. Wait for a few secs
Download Driver here
https://www.canonprintersdrivers.com/canon-pixma-mg6100-series
Oct 30, 2015 | Canon PIXMA MP160 All-In-One InkJet...
Scan
not click on preview just next finish
Apr 24, 2013 | Samsung SCX-4300 Monochrome Laser...
UNABLE TO PRINT FROM TRAY 1 PANASONIC
Try this:
Open a document to print
Open print preview and select properties/printer properties
Look for Paper/Quality, then Source
Choose Tray 1
Mar 22, 2013 | Panasonic KX-MB1500 A4 Mono Laser...
How does one lower the scan resolution on the Dell 2135cn? Currently, a document of twenty - or so - pages, saves to a pdf file of ten-plus megabytes. Far too large to attach to email.
You need to adjust the resolution in the software. Are you using the Dell software and PaperPort or another application?
This will be easiest to do when you launch the scan from the computer. If you have the TWAIN driver loaded, load the document to scan in the ADF and open Paperport. Click FileScan and the available scanners list should open. Choose your scanner (otherwise click the Select button on the left side of the window). Then click OK. Click on the Scanner Display dialog box on the left of the window. Click on Preview. Then adjust the resolution by clicking on the Image Quality tab.
If the document contains is only a series of picture or you have the WIA driver loaded, then use Paint or PhotoGallery (Vista includes the program, but it is available for XP or Windows 7). Then choose File > Import from Camera or Scanner > From Scanner. Open the Advanced Properties dialog box by clicking on Adjust the Quality of the Scanned picture.
I hope this helps.
(The default resolution is used when you launch a scan from the unit itself. It is possible to adjust it once the software loads but you must use the scan to file option, instead of scan to e-mail. Then attach the resultant file to your e-mail.)
Feb 26, 2011 | Dell 2135cn All-In-One Laser Printer
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
Dec 22, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Hinge for document cover broken; squeal like something needs lube
The hinge is LP2403001, if you google the part No. you should be able to find it for around $15.00, for the noise, try powering up with toner and drum removed, many times the noises come from generic or worn out toner carts.
Aug 25, 2009 | Brother MFC-8840D All-In-One Laser Printer
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
ERROR EE2 WARNING
one bad toner has jammed or toner drive clutch has fault. open right cover and you can see witch clutch makes noise. or toner drive moter has problem.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
ML2250 Laser
Dead/dry fan bearing.  Either: * order a new fan and replace it  * peel off the sticker on the fan and add a tiny drop of sewing machine oil - I did and has fixed mine (not sure how long)
Pretty easy machine to disassamble without a manual as long as you don't force anything. Well engineered 2- 4 screws for each panel and some very mild flexing of panel clips required. Remove in order: back cover (ease past power switch); top cover - have to lift to about 30deg at front; front cover (unplug wire to light assembly, unclip top + push forward); side cover (note hooks on bottom; unclip top and push to rear).
Aug 24, 2008 | Samsung ML2250 Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
HP ScanJet 2400 Flatbed Scanner Logo
42 people viewed this question
Ben Johnson
