Question about Miele Washing Machines
Miele WS5426 Heater Element Replacement
Hi Guys - How do I replace the 2 heater elements in a Miele WS5426 Commercial washing machine. They appear to be held with spring (star) clips as opposed to with a single nut as most washer elements are? - Terry
On the WS 5426 the elements are mounted at the bottom of the drum of the accessed by opening the front of the machine.
Removal of the elements will involve destroying the rubber seal and can be done by cutting two vertical slots with a sharp knife in the seal and then pulling hard on the seal with a pair of pliers. It is not necessary to remove the spring clamps or drip shield but it will aid access to the seal.
Posted on Jan 27, 2014
barkencoa
  • 3463 Answers
SOURCE: Hi, i have owned my Hotpoint Ultima WT960 washer
I would concur that is probably the element and or thermistor attached to the element that is causing the problem.
Before commiting to replace, try disconnecting the supply to the element and trying it again, if it does not trip, then this proves element and or thermistor faulty.
Posted on Jan 04, 2011
Testimonial: "thank you for the help this is much appreciated!!!!"
barkencoa
  • 3463 Answers
SOURCE: Washing machine heater not working
Only way to be sure if it is the heater, is to test it with a meter.
They are a fairly straightforward job to replace
Please rate my solution.
Thanks..
Posted on Nov 17, 2009
beltronic205
  • 1474 Answers
SOURCE: F-08 error message on Hotpoint Washing machine
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Posted on Oct 07, 2009
murdozzz2
  • 75 Answers
SOURCE: How to change the Heater Element in Hotpoint WF210G
hi there, this heater can be a bit fiddly but can be fitted from the back first remove the 10 or possible 8mm nut from the heater and all wires then with a pair of pliars grip one of the terminals and pull the heater 2-3" out then with a small flat head screwdriver start to prise the rubber seal out all the way round until the heater drops out don't be scared to use a bit of force on the seal as your new heater comes compleate with new seal
hope this is of some help murdozzz
Posted on Dec 09, 2007
  • 209 Answers
SOURCE: Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Posted on Oct 07, 2007
How do i open a miele w3821 ?
How To Test And Fit A Washing Machine Heater - YouTube
? 5:08
www.youtube.com/watch?v=xZBtEt8HvxQ
Jun 17, 2012 - Uploaded by Kenneth Watt How to test a washing machine heating element and how to remove and refit one. We also show you a little ...
Oct 02, 2015 | Miele Washing Machines
Have a Miele 1612 washer whose heater element comes on during any cold only program. As we are off-grid, any unnescesary power useage is unacceptable. Is there something I can reset, or do I just remo
Hi Ed ..
The following is from the Miele handbook and would indicate that the machine can have the water temperature adjusted...... However I suggest that by merely disconnecting/removing the element
the machine's temperature sensors would not allow the machine to work..
A compromise may be to select the lowest wash temperature (ie 30c) This is better than cold water for detergent economy and effectiveness, and machine life.. I understand your situation.
Good luck
Nomess
http://m.miele.ca/OperatingInstructions/en-CA/Laundry/Washing%20machines/Previous%20models/Miele%20Washing%20machine%20Manual%20W1612.pdf
Page 50
Tap water line (cold water) The tap water connection is established using the inlet hose with the blue marking. If the washer is connected to this line only, the appliance will need to be reprogrammed to cold water fill only. Please contact your Miele dealer or Miele Customer Service for reprogramming instructions.
Feb 05, 2015 | Miele Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
How to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Sep 26, 2012 | Miele WT945 Front Load Washer / Dryer
Novotronic w844 when washing large load sticks at rinse program and has to be restarted often several times
It sounds like your heater element is not working. If the washer doesn't reach the desired temperature it will not advance to the next level. Try to do a cold wash and see if it completes the cycle if it does you need to replace the heater element.
Feb 01, 2012 | Miele Washing Machines
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Dec 09, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
572 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
