Question about Creda C361E Electric Kitchen Range
Cooling fan running continuously
The cooling fan that blows air out just under the control panel is running perminantly - is there a thermostat I can replace?
  • Anonymous Aug 10, 2008
    creda concept solarglow model-48341. the fans keeps running when the oven is turned off, continously. how can I fix this problem?
    Many thanks Stu
CREDA Kitchen Range -The cooling fan and oven fan run contiuously when the oven is turned off. The only way at present to stop them is to switch the stove off at the cooker supply box. When you switch it back on at the supply box, both the fans start start running again. How can I fix it ?
Many thanks Stu.
Posted on Aug 13, 2008
SOURCE:
My Coleman model 6806-852 does not shut off when the thermostat tells it to.
Check out the limit switch sounds like its not shutting off .
Feb 14, 2018 | Coleman Heating & Cooling
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
Fusebox location
Relay Center Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Let me know if this helps. If not, let me know.
Circuit Protection The fuse panel is located below and to the left of the steering column.
Fuses are a one-time circuit protection. If a circuit is overloaded or shorts, the fuse will blow thus protecting the circuit. A fuse will continue to blow until the circuit is repaired.
Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal.
Aug 07, 2010 | 1991 Ford Tempo 4 Door
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
No cooling, coils frosting up, defrosted with blow dryer several days ago and cooling fine again, but frost is building up rapidly again. I suspect a defrost heater, please confirm and where to order a...
The evaporator (inside) coil can ice up for the following (typical) reasons. Check the ones that you can and hire a professional refrigeration technician if you can't find the problem yourself.
1. Thermostat isn't shutting off. (Does the compressor run continuously? Can you turn the compressor off while it is running by turning the freezer temp control down (but not off)?
2. Internal fan (evaporator fan) is not blowing air. Possible causes: fan blades hitting something; debris blocking air flow; fan motor bad; no power to fan.
3. Low refrigerant (freon) charge. Need a technician for this one.
You can get thermostat or fan motor at a local appliance parts store. Try googling "appliance parts <yourzipcodey>"
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 1993 yellowstone camper with a coleman wall thermostat. on the bottom of it- it has a heat/cool switch on one side and the other side has a low-high-fan switch. when we run it on low or high it...
These unit are set up for continuous fan operation when turned on. It does not have an automatic position on your thermostat such as in your house. Set the fan speed to what you are comfortable with and let the thermostat control the temperature.
Jul 21, 2008 | Coleman Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Creda C361E Electric Kitchen Range Logo
673 people viewed this question
Top Creda Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
