Question about Epson Stylus Photo R260 InkJet Printer
Epson Print CD software problem
When I try to insert a picture from the import dropdown, the software won't bring up the folder on screen. This is the first time I've had this problem, and I have been using this printer for over a year now. Do you have any idea how I can solve this problem? Thank You.
The source selected in the printer driver is not appropriate for the CD/DD tray that is loaded in the printer.
What should I do?
Posted on May 31, 2008
SOURCE:
Gt b5722 mobile
When you plug in the phone via usb a box should come up asking you what you want to do with the device. Try to use the import or explore feature. Check to be sure your settings are correct from the " view" dropdown in windows explorer for view subfiles and folder. I would make sure that you have the right permissions or are a+ administrator. Also some sd cards have a lock feature check for a switch or padlock icon on the physical disk
Dec 02, 2013 | Samsung B5722 dual sim - pink
How do you print a picture from computer?
Your printer came with an installation CD. If you have installed the content then you should have Epson EasyPrint v3.10 on your computer and that's what you need to use to print. With Epson EasyPrint, you don't have to select your print settings from the Epson printer driver. Instead, the most important Epson print settings are embedded right into your software's Print screen.
If you don't have it, you can get it from Epson website. You will have to filter the results to get the right one for your operating system.
Also, you can read more about Epson EasyPrint here.
Dec 14, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I am running Mac OS 10.5.8 connected to an Epson Stylus Photo R340. Recently I tried to use Print CD and repeatedly get an error telling me theCD Print Driver is not installed, I have tried to reinstall...
we have same mac os, delete the software that was been installed then go to LIBRARY then go to RECEIPTS then delete the epson names you have in that folder then empty the trash then restart your mac install the software again then click the update after you finish installing then after updating online finish reboot and use.
Aug 27, 2010 | Epson Computers & Internet
How do you enlage a picture
There are few methods to enlarge the pictures. You may open MS-Word - insert the picture (insert - picture) - now select the picture in MS-Word and extend the picture with the mouse. Now save as the word file in HTML format and check the saved folder - you will get the enlarge picture file there in the folder.
Another way to enlarge is Photoshop. Open Photoshop - import the picture - select the picture and enlarge it - then save as usual.
Jun 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Forgot pin number for epson stylus cx6400
If you forget your PIN code, you can regain access to the CX6400 by running the security lock program from your computer:
1.
Insert your Stylus CX6400 software CD-ROM.
2. Windows: If you see the Software Installation screen, click Exit.
Open the
SecurityLock Tool folder on your CD-ROM, then double-click the program file located in that folder.
Macintosh: The EPSON folder automatically opens (if it doesn’t, double-
click the EPSON CD-ROM icon). Then double-click the Security Lock icon.
Nov 24, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
Printing my own pictures
I use the Epson Print CD software that cam with my printer. If you refer to the numbers in the attached picture I can show you how to select your own pictures to print on CD. 1. Select the "background" icon in the side bar. 2. Choose "select image" 3. Choose "file" & browse to the folder where your pictures are. 4. You can also choose to import the clipboard if you copy an image from another application or choose "twain" to get images from your scanner or camera. In the example I chose the "sunset" picture for my CD. Try the above & let us know how you get on! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Epson Stylus Photo R220 InkJet Printer
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Epson Stylus Photo R260 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
