Disk manager for hitachi
From where can i get disk manager for hitachi that is also capable from cleaning up master boot records?
    Problem Solver:
  • 19 Answers
Disk Manager is a HDD Diagnostic Utility which was developed by Seagate and will only work on Seagate make HDD. U cannot apply it to other Brand.
Posted on Mar 12, 2008
6ya staff
SOURCE:
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
Error Loading operating system
CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
Dec 31, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Error "boot manager not found. restart " keeps cycling this. Just installed
Probably no operating system on the hard disk (or the Master Boot Record is corrupt).
Nov 20, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
Master Password for 2.5'' Hitachi laptop HDD
if locked while booting up, before even windows is loading: you've got a master password in BIOS to worry about.No way but to ask the manufacturer to remove it.
if you cannot access windows anymore after booting up:
boot up from a win cd, go through setup,
install a new copy of windows and try to find your personal files on the disk, back them up and reboot from a win cd again, this time format the whole harddisk and set up a clean, new installlation of windows.(warning: all beforehand data will permanently lost then)
good luck
Jun 05, 2009 | Computers & Internet
Invalad BOOT.INI File from C:\winnt\ NTDETECT
You have to rebuild the boot.ini file. That is going to require a disk and do a repair install. Or the MBR (Master boot record) is corrupt. Software like Paragon partition manage can check your MRB and see is it is pointing to the correct boot.ini file path.
Jan 16, 2009 | HP OmniBook XE3 Notebook
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Sep 28, 2007 | Western Digital Caviar 40 GB Hard Drive
Open Questions:
Computers & Internet Logo
1,219 people viewed this question
Ekse
Marvin
Marvin
