Ordinarily, the blades are removed and replaced as follows:
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
In your case the retaining clip may have broken off. With the blade removed, push that same gun metal colored bar in. You should see the other end of it move in unison just behind the nylon cog that moves the blades when they are installed. Check the tip of that other end to see that the "turned back on itself" rounded portion is there. That's what holds the blade on. If it is missing, you will have to replace the part (the tongue part has to be removed to do so since the retaining clip part is under it, with a small spring holding it in place). A new one can be obtained, I think, at:
http://www.clipperrepair.com/parts.htm?brand=8
Hope this is helpful to you.
