Question about Intel D845GVSR Motherboard
Thx for your response. i checked the jumper settings but not sure they are correct. can you elaborate
  • 25 Answers
U check the manual or (1 2, 5 6 ,9 10) will short the jumper
Posted on Mar 11, 2008
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
My hard drive wont boot it is as if it is not recognised
Can you please elaborate more about your problem?
This is a partial help for you. Check the HDD Cable of your had Disk drive or check the Jumper. Check the BIOS settings, then set the HDD to first boot priority.
hope it helps you.
Jul 15, 2011 | Computers & Internet
Insert boot media ?
Have you added a new hard drive lately? If so.. You need to check the jumper settings and make sure you have it set correctly depending on whether its the master or slave drive..
If your not sure, just change the jumper to cable select.
Sep 06, 2010 | E-Machines eMachines Desktop PC
DVD drive from Matshita UJDA 755y doesn't give any response. Hardware profile looks good and free from any conflict, driver is installed (version correct? I don't know) and shows available for use. Is...
Did you set the jumper setting of the Drive eg master/slave/cable select so as then drive to work with the machine ? or is the cable put correctly .
If you will be able to see the jumper setting of the drive choose master then connect and power up the machine.
Your lap top should be able to detect the drive and automatically install it till ready to use .
good luck
Dec 28, 2009 | IBM Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Mercury motherboard pi945gcm cmos setting dose not save shut down machine then power on machine see press f1 date & time not save
This sounds like your battery may be bad or not locked into place fully. Also on the mother board there is a cmos jumper that is used to clear your bios check to make sure the jumper is set correctly an also inspect the jumper to make sure it will make good contact to the jumper posts. Good luck I hope this helps. Also when you set the time in your bios make sure to exit with f 10 key or whatever the save and exit key is for you bios.
May 15, 2009 | Computers & Internet
Intel d945gnt
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
Nov 18, 2008 | Intel D945GNT Motherboard
Can i format without the bios password?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Nov 08, 2008 | Panasonic Toughbook W2 Notebook
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
