Question about Dishwashers
Candy Dishwasher Power Trip Problem...........................
Hi - I have a Candy Dishwasher model number CI 7100 - it is now about 4 years old & the fault that has recently appeared results in the mains supply tripping out at various points in the cycle. I strongly suspect that that the problem is related to a fault with the heating element as I am able to run the cold rinse (which obviously includes pumping water in & out of the machine) as many times as I wish without problems. I am resident in Spain currently and want to have something concrete to go on before I speak with the service centre here (the language barrier always makes things a little fraught anyway!!) as I would like to avoid any unnecessary additional expenditure - is it a straightforward job for one to replace the element oneself?
Please advise.
Many thanks
Adam Bennett - adam@makingitwork.eu
  • adam99 Mar 12, 2008
    Hi Dave
    Thanks for getting back to me so quickly - no the water does not appear to heat at all now - but ofcourse when the power trips out I have to manually advance the program switch by one or two clicks in order for the wash to continue so I am probably not going to be utilising the element in any case.
    Is there any way to identify precisely where in the cycle the element is switched on and thus confirm my suspicions - and is the heating element an expensive item to replace and can I fit it myself easily enough?
    Regards
    Adam
  • David Duffell
    David Duffell May 11, 2010
    Hi Adam,
    Does the water ever heat, or does the RCB trip every time you suspect the heating cycle starts?
    Cheers....Dave
  • 30 Answers
Hi Adam,
Those are tough questions, it depends on accessibility of the parts in question, and the tools you have available to you.
It’s worth remembering that 80% of d/washer faults are mechanical in nature (even the electrical ones). I know that sounds like a contradiction in terms, however I am referring to things like loose connections, broken wires worn parts etc.
First thing to do is have a good look and weigh the job up (English colloquialism) A bad Neutral connection to the heater element would give you these symptoms. An open circuit heater would likely do the same. Moisture in an inappropriate place could also give similar problems.
After gaining access to the business end of the element, check for corroded connectors. If all seems well, and you have access to a multimeter, set it to ohms and measure across the two heater terminals with the wires disconnected. If you get no reading, then the heater element is open circuit and requires replacing. If you do get a reading, and still think the element is suspect, you could try disconnecting both feeds to the heater (not the earth) taping them up with good quality electrical tape so as to isolate them, then try your dishwasher on a cycle where the water would normally be heated. If it doesn’t trip the RCBs then heater is suspect.
This is a good starting point, and will enable you to assess weather you feel comfortable tackling replacing it or not (assuming it is faulty). If you don’t feel comfortable, may I suggest that you purchase the element from a spares supplier yourself, there are many good suppliers on line. Then have a service engineer fit it. This prevents your friendly repair man charging you $90.00 for a $20.00 part.
Of course, it goes without saying, that all these tests should be carried out with the appliance disconnected from the mains supply.
Good Hunting!
Regards……..Dave
Posted on Mar 12, 2008
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
Candy CD242
Try this link & check that model number. They had a 252 but no 242: http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=3
Mar 25, 2014 | Candy 24 in. CD623 Free-standing...
Candy dishwasher. Program setting won't change
what is the make and model number?
May 21, 2013 | Dishwashers
Why does my dishwasher trip our electric when we switch it on ?
There can be a possible short or an electrical leak- if ELCB is used- that seems to trip off the circuit. this can be a short in the main control panel which is the power section.
the ideal way to go about is to ISOLATE the circuit , so remove the control boarrd leads and check, then remove the outputs from the control board, check for leak from the board which will confirm the case.
Take precaution when checking with live circuit.
Sep 14, 2011 | Candy 24 in. CD622 Free-standing...
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Dec 12, 2010 | Candy Dishwashers
No electric power going to our dishwasher
there could be an internal fuse on the pcb which could be blown
May 17, 2009 | Dishwashers
Candy cs 455m dishwasher
Welcome to fixya.
I'm Huuum at your service.
You said, Candy keeps blowing the fuse. It is not the main fuse in the house(was checked). I
You think it may be the heating element. You asked any advice?
I feel you have a short somewhere . and who knows where? How old is the appliance and what did it cost?
I've seen 3 or 4 people in the past 24 hours that replaced the heating element in the same candy 455 dishwasher and still had the problem.
They told me they felt they did not want to spend any more money ont his unit cause they said, it was an inexpensive model!
So my clients told me!
Here is an interesting report I just read.
Repair or replace you appliances?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive appliance
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you sign off!
Thank You, HUUUM
May 22, 2008 | Candy 17 in. CS455 Built-in Dishwasher
Candy fridge freezer
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
421 people viewed this question
Top Dishwashers Experts
