No power Hi I have no power from a Hitachi AX-M135 power amplifier. Checked plug 3A fuse, F300 f3.15AL fuse and fuse on pcb 1204D2-11. Any ideas
Hello
This isn't a solution I'm afraid but we have also suddenly lost all power for the same Hitachi model (have checked the fuses too) and were wondering if you ever found a solution to your problem?
Posted on Aug 18, 2008
Hi i have a hitachi ax m140 power amplifier there's no standby light dead can you help please
Check the power supply rails on the secondary side of the power
transformer.
• Check the presence of AC outputs on the transformer secondary
windings
• Check the diodes and capacitor circuit
• Check the regulator circuits
Post image so we can undestand better ( only if possible )
and guide you accordingly.
Aug 02, 2012 | M-Audio Audio Players & Recorders
My mrp f300 amplifier shut down in my truck when I was driving with mid volume and has made no noise just went silent and the light hasn't turned on yet I jiggled some wires and checked for loose wires and...
hi check the ground wire over time the ground loses good conection. check the fuse on the amp outer or inner depends on modles also check all fuses thanks hope been some help
Sep 27, 2010 | Alpine Car Audio & Video
How can i check what is wrong with my amp in order to get it to turn on
If your amplifier is not turning on, it is important to have an idea of the cirrcuit within to probe into the circuits.First of all look for the power spply lines, check the voltage to the amplifier with a multimeter in the volt mode. Now look into the circuit where the power goes in , check for any signs of fused resistors, fuses within or even burned tacks in the PCB. If voltage comes into all the circuits and to the output drivers, be sure to check for the input siganl and the preamplifier section. The signal from the head unit must be checked or else you can use a test signal- audio- to confirm. With this you will have an idea of the fault section. Get help if not familiar with the electronics section , tampering will be irrepairable. Good day
Aug 11, 2010 | PPI2360 Car Audio Amplifier
Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Mar 09, 2010 | Audio Players & Recorders
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
Hifi
Unit obviously has circuit problems, Have serviced
Apr 27, 2008 | Audio Players & Recorders
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
247 people viewed this question
 Grubhead
Grubhead
