Question about Epson Stylus C43SX InkJet Printer
Refilling cartridge ink
Instructions on refilling cartridge ink both black and color
  • 4 Answers
First off you need to re-set the IC on the cartridge, for this you will have to purchase a Chip re-setter, google it on the net or check here for links
filling the cartridge is easy, but you need to get the right ink or you will mess up the printer head, normally when you order ink it will have the instructions, avoid kits that tell you that their ink is universal
The cartridge cannot be filled from the bottom, looking at the top of the cartridge almost directly above the were the ink comes out, you can see / feel an indent in the plastic label, stick the needle / filler in there - it should take about 6 - 8 ml of ink - you might find it better to try and fill the cartridge by facing it up, so that the ink can flow to the back, do it slowly, take a break if need be, you will be able to judge when it is full.
The Colour carts fill the same as the black, the colour code is correct on the original cartridge - Blue, Red Yellow (not like the sneaky HP carts)
Posted on Mar 24, 2008
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
    1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
      Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
    2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
      Repeat whenever you run out of ink.
    Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
    I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
    Your printer uses the following cartridges:
    canon-pg-30
    Black Pigmented
    canon-cl-31
    Color
    canon-pg-40
    Black Pigmented
    canon-pg-50
    Black Pigmented canon-cl-41
    Color
    canon-cl-51
    Color
    ou find the refill instructions for your cartridges in the book at the link below:
    Download Inkjet Refill Instructions
    You can also buy refill kit here: inkjet refill products.
    You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
    Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
    Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
    Swap black inks with Epson 9800
    By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
    www.colorbyte.com
    I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
    Mar 20, 2008 | Epson Stylus Pro 9800 InkJet Printer
    Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
    Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Refilling ink cartridges
    hp74a.jpg HP #74 Cartridge Refill Instructions
    Black cartridge
    Instructions
    1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
    3. Fill the syringe with 20ml. of black ink.
    4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
    5. When finished, replace the top label or leave it off (it will make no difference in the printing).
    6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
    Or print the following pages:
    http://www.refillinstructions.com/black.htm for Black
    For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
    A Refill Kit should include Ink plus the following:
    One 30cc Syringe
    Jan 14, 2008 | Office Equipment & Supplies
    Epson Stylus C43SX InkJet Printer Logo
    83 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
