Question about Delphi Roady XT XM Radio Receiver
Roady XT Problem
When I turn on my radio all it sais is loading.
I tried the internet refresh code multiple times, No luck.
Is it in need of repair.
if so where can I get it fixed?
I live in Canada
Thanks,
Alan
So that's the problem? Have you tried to disconnect or unplug all the cables and reconnect it again? if not, then do it man, make sure that you connect the antena properly. Then turn on ayour radio and do this procedure, tune to channel 1, then live it there for 20 mins. then tune to channel 7, when you gear channel 7 tune to channel 175, when you here those channels, its working again, not if not, then do refresh your radio. just follow the procedure properly and surely it will work.-Mark
Posted on Dec 19, 2008
  • 28 Answers
Sounds like a software glitch, you should try
I need to get my Delphi XM Roady, Roady2, or RoadyXT repaired, where can I take it?
At this time, Delphi does not currently have an authorized repair center. If you are within your one-year warranty period, please contact the Delphi Warranty Center at 1.877.GO.DELPHI (1.877.463.3574). Hope this is helpful
Posted on Mar 16, 2008
My roady xt stopped getting channels 70-78, I've had the signal resent but it still won't work?
First, make sure that you have a very good signal - check channel 1 audio. Then go to the MENU and 'RESET' to factory settings.
Then call SiriusXM and have them send a 'REFRESH' signal - leave it on channel 1 for about 20 minutes, then check and see if you have Channel #4 - if you do, then dial-up Channel 71 - you should have Sinatra - UNLESS, you have a MUSIC-ONLY subscription, which limits your channels to only the specified ones. But, with XM Select or higher, you should have channel 71 again. Let me know how it goes. Good luck.
Aug 25, 2014 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Can't get Roady XT to turn on. Previously wouldn't load signal.
there is a bad connection on the voltage input on the radio. look in the hole you will see a copper contact if it wore, you will see a hole in it, you needed to bend it towards the center contact just a little bit. then try it again I worked on mine
Dec 26, 2008 | Delphi Roady XT XM Radio Receiver
Stations dropped
Go to refresh.xmradio.com and insert your radio ID and click submit, it will send a refreshed activation signal to your radio and you should have your channels back within about 15-20 minutes
Jul 15, 2008 | Delphi Roady XT XM Radio Receiver
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Jul 20, 2007 | Belkin F5X007 XM Radio Receiver
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
326 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
