Question about HP Compaq nx6125 Notebook
Black screen..computer working
My laptop suddenly had black display..but still working..ports are loose
  • yeshdass Mar 11, 2008
    thankyou, will try this, sounds right as my son was in middle east with laptop..how can you protect against dust..apart from covering it when not in use in dusty countries? should you regularly blow into openings to prevent it clogging up! help very much apprehiated..and I'm a madam not sir:)
    Genius:
  • 1,011 Answers
Hello Sir,
This is the Dust problem.If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Posted on Mar 11, 2008
M93p suddenly the screen goes black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck
Jun 19, 2014 | Lenovo M93P Tiny I7-4765T 8GB 500 WIN7/8
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Acer 4320 can not switch on properly. after a few minutes turn on, suddenly black out.
The problem is most likely the DC jack in the laptop, causes are no power to intermittent operation, but if the screen blacks out it means the LCD display has issues especially if the rest of the laptop is working, could be a loose video cord from the screen to the motherboard has come loose.
Jun 10, 2012 | Acer TravelMate 4320 Notebook
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
I was just using my mom's acer aspire when suddenly a blue screen appeared that stated it was preparing for a crash dump. The computer will turn on and sound like it's starting up, but then it stops and...
from what yu say if i infer correctly then
when powered on the system powers up properly and the HDD and CPU are running fine but there is no display on the screen and is black,
first try the this step, try connecting an external monitor to the VGA port (generally in blue color) and see if you have a Display on the external monitor.
the black screen generally means that either the Display section is not getting power or the invertor board is damaged and this needs professional help in fixing / replacing it.
hope could be of help
Mar 28, 2011 | Acer Computers & Internet
I have a gateway laptop W340UI/MT3705 that is booting up but the screen is black and yes seems bad to me. But attaching an external monitor brings up everything normally. Could there be a loose...
the computer should least display anything when malfunction were present. Also, the computer would provide message details of the condition if any suddenly were encountered. Observe the computer for any new features thought as unusual. Consult with technitians
Feb 09, 2011 | Gateway MT3705 Notebook
My computer was working fie. i closed it for a second and when i opened it again the screen was black. the back light still worked but the screen was blank
Try testing it out through your external ports like the vga, svideo (hdmi if you have one) port to a external monitor, or a tv and see if you get anything there. If you are able to get display to a tv, or external monitor through your external port, then you might have a issue with your screen inverter, or loose connection somehwere between your screen and your laptop base. Secondly if you can't get a display to a tv or external monitor using the external ports, or you get the same display like your screen, then your vga chipset is screwed, and you motherboard will need replacement since the vga chipset is solder onto the motherboard. At this point you can either try to replace the motherboard, (which is going to cost you almost or more then a brand new laptop) or decide to go ahead and get a new laptop.
Feb 01, 2011 | Compaq Presario CQ60-220US PC Laptop
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
Apr 28, 2017 | Sony SDM-HS74P/S 17" LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq nx6125 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
