Question about Rockford Fosgate Punch 500a2 Car Audio Amplifier
No power working fine for a couple of days and then losst power. Checked all connectoins and everythings fine , just no power.
  • Emanuel Gissendanner Mar 11, 2008
    where exactly would the fuse be ? This amp doesnt have one as for as i can i tell. Is there some where i can send or take it to get it looked at/
  • 129 Answers
Good day.
Have you checked on the fuse terminals?
Maybe the zener diode along B+ and ground got shorted when supply was reversed.
Check for for the continuity along the supply line. Also, consider if there was a sudden surge of supply that busted parts along the filter line of your unit.
chris
Posted on Mar 11, 2008
Engine stutters upon acceleration
you have changed everything so it should go unless you haven't checked the fuel pressure and injectors of problems in the carby if you have one as not all faults you describe are in the electrical system
May 02, 2014 | GMC Sonoma Cars & Trucks
Oil Pressure and Neutral Swith issue 2003 Sportster 1200
just replace the ignition switch because due to moisture it might have been damaged
Jul 09, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Rode my bike a couple of days ago, and everything was fine. When I tried to start it up, nothing happened, checked the battery and it was fine, correct voltage and all. Checked all the fuses, none were...
probly need a new starter relay-located by batt n has the cables attached--also chec wiring for any flaws--I wood make sur batt cables r tite n clean-ur welcome olschooler
Jan 20, 2010 | 1979 Yamaha XS 650 F
The directional light, wipers, brights, are not working
the combination switch may be bad. (wipers, turn signal, hi-lo beam switch)
Oct 13, 2009 | 2008 Dodge Avenger
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Blowing 30 amp fusible link
check all ignition feed power circuits.get the manual that come with your truck in the glove compartment. it will tell you what fuse that is.because it has every fuse and relay in your truck.
Apr 09, 2009 | 1989 Toyota Pickup SR5
Brakes
Try to jack up the wheels and turn them to see if there is no seized brakes/calipers. Let us know how you get on.
Cheers
Nov 03, 2008 | 2006 Chevrolet Trailblazer
Lose power to half of the systems
My solution turned out to be a fusible link behind the battery. Cost me $55 for a tow and another $75 to track down the problem. I wonder if yours is a loose connection on the same line as the fusible link. Or maybe yours has a circuit breaker. My question is, why did the fusible link go in the first place, and what caused the relays to click off and on--maybe the computer got confused?
Sep 20, 2008 | 1994 GMC Safari
Rockford Fosgate Punch 500a2 Car Audio Amplifier Logo
95 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
