Question about Sony Ericsson Z530i Cellular Phone
How do i open the phone to replace the lcd screen
I opened it by gently pushing a very thin knife between the rear and the middle housing,and go around the edge
then use a tork 6 screwdriver and thats it
groetjes
Posted on Mar 12, 2008
Replace screen
Replacing the LCD of a phone is a bit tricky. Some times LCD are soldered into the board and sometimes it's just a putty type. To know what type your LCD connection is, you must see deep inside the board. To do this you have to open your cellphone. Do not just Pry open your phone, one way to safely open your phone is by using google. Yep, that's right. Search for a teardown of your phone model i.e: Nokia 7230 teardown. This helps you to disassemble your cellphone. Now when you see what type the connection of your LCD is, it's up to you if you want to personally do it, or let the technician do it. You can buy cellphone scraps from ebay or Amazon. Good luck mate, I hope this helps!
Jun 19, 2013 | Nokia 7230 Cell Phone
How to replace lcd screen
Hello! open the link and follow the steps:
click here:
once dissembled you can re assemble your new lcd!!
please give response!
thanks!
Dec 13, 2011 | Nokia 6210 Navigator Cell Phone
The internal screen on my LG Env Touch remains blank after opening. The interenal keypad lights up when opened, but not the screen. The phone did not get wet, to my knowledge, and was functioning properly...
Hi, most screen problems usually happen after a fall or a knock against a solid object. There are two things that might have happened here. One might be, the screen got a hairline crack and the connection to the lcd is broken. The other is that the lcd did not crack, but the connector flex cable is disconnected. The first requires a replacement lcd. The second requires an inspection to see if the flex is disconnected or broken. (You will have to open the phone). If you cannot DIY, then take it to a repair shop. Replacement lcd can be found on ebay.
Jul 09, 2011 | LG enV Touch VX11000 Cell Phone
I need the steps to replace the lcd screen.
Many cell phone users wrongly sell, or give away their cell phones when the LCD screen cracks, breaks or goes bad. Removing and replacing the LCD screen yourself is much cheaper than buying a new phone. Most cell phone parts or components can be purchased online at cell phone repair website such as CellularDr.com or Cellphonesshop.net. Replacing the LCD screen yourself, however, may void your warranty agreement.
Switch off phone,
Get a screw driver and unscrew the top where the screen is located,
(screw is located when flip is open).
Carefully remove screen from hook(when it is Pinned too),
Fix the replacement screen and screw back necessary screws on the phone.
And your Dawn.
Good luck.
Jul 15, 2010 | LG TRAX Cellular Phone
The lcd screen cracked and won't show display but touch screen still works and you can turn off and on.
The LCD panel and Touch screen panel were both have separate circuit connection. the covering panel of the LCD is the touch screen the inner is the LCD, replacing an LCD is quite just bit easy all you need a replacement LCD, you can purchased it online or via ebay. and you'll also need a dismantling guide and a very cheap opening tools.
find it here: all mobile phones dismantling guides
Jun 21, 2010 | Samsung SGH-A877 Impression Cell Phone
Broken Screen Replacement
Dear it is very easy but a little bit tricky to change its screen, but if have you have any experience of repairing or opening the mobile phone then it will be more easy for you. you just open the mobile phone carefully because it has basically two parts screen part and Keypad part so be attentive while opening. after open the phone you just put off the strip (Jack) of LCD from the keypad part then put in the new LCD strip on it. reassemble carefully, you have done now...
Thank you
May 17, 2010 | Nokia 2760 Cellular Phone
How do you replace the lcd on samsung t809
have you found out how to replace the screen yet?
If not post your message again. I can walk you through it.
Jan 09, 2008 | Samsung T809 Cellular Phone
Replacing LCD screen
just follow the basic steps in opening nokia phone... look for any screws and unscrew it, if thiers no more screw but still you can open it. probably it got locks, so look for it and snap to open it then you open your phone.... in changing your lcd, thiers a flex connector that connects your lcd to its board. to open it use a tweezer to open it and do it slowly to avoid damaging the flex...
good luck...
Oct 10, 2007 | Nokia 7373 Cellular Phone
LCD lights up, but is blank when i open the flip
yeah that is possible. make sure you know what you are doing and don't damage the working LCD screen it might just be easier to replace the whole cuircuit board that the LCD screen is on.
Feb 21, 2007 | Motorola Mobility V265
Sony Ericsson Z530i Cellular Phone Logo
48 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
Shehu Pro
Shehu Pro
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
