Question about Olympus Camedia C-350 Digital Camera
CARD ERROR using 1GO xD card , the C-350 gives the following message : CARD ERROR . Using 32 MB or 16MB it's OK . is there solution please ?
  • 1 more comment
  • alb8444 Mar 12, 2008
    card setup; i select format, "message says caution erasing all," and then "card error"
  • debbers100 May 17, 2008
    Camera displays-Card setup with the following options:
    Power off
    Format
    When I select format, then "yes"
    a Caution erasing all message appears
    then a card error message appears
    I have a D-560 zoom digital camera
  • Brian Wolves May 31, 2008
    I have the same problem, if i use 16 or 64 MB card all is well, but when i try to format a 2GB card I get the error message "Card Error". As you can't do anything with the camera unless you format the card there are no other options that i can fathom.
  • 3 Answers
Hi, don't know if this is any help, but i had the same problem with trying a 1gb card, i think that this camera will only accept up to a 512mb! If you go higher it will not accept it. 512mb is highest memory card you can go with this camera! Take care and good luck. Kerry
Posted on Jun 23, 2008
6ya staff
SOURCE:
How do i get my Olympus D560 to use an xD M+ memory card? I keep getting card error message.
The Olympus compatibility chart on their website says that your camera works with type M and M+ sizes 256MB - 512MB.
The chart also says 256MB - 512MB for type H and 16MB - 512MB for standard xD cards.
It looks like the largest size xD you can use of any type is 512MB.
The D560 is quite an early digital camera and it is not unusual to have card size limitations.
Mar 21, 2010 | Olympus Camedia C-350 Digital Camera
Hi, Can't find 256 MB xd picture card for older camera?
Hi Mark,
I did some checking and found that another expert had a similar question on 10/2/08. According to kenshin99, the limit on the cards is 256mb but some have had luck with the 512mb cards.
I think your best place to find those would be on sites like eBay or Craigslist
Jan 10, 2010 | Cameras
XD memory card confusion
The xD-Picture Card (xD stands for "extreme digital.") is a flash memory card format developed and introduced to the market in July 2002 by Olympus and Fujifilm, and manufactured by the Toshiba Corporation. xD cards are in Olympus and Fujifilm digital cameras, and are available in a range of sizes, from 16 MB to 2 GB currently. A higher-performance xD card known as Type M came out in 2005, and uses Multi Level Cell (MLC) architecture.
An xD card is 20mm x 25mm x 1.78mm and weighs about 2.8 g, making it significantly smaller than the nearly matchbook-sized CF card and about half the size of the SD/MMC card. As far as size goes, it is much closer to miniSD or RS-MMC. The manufacturer listed write speeds for xD-Picture Cards are: for the 16 MB and 32 MB card, 1.3 MB/s and for the 64MB and higher cards, 3 MB/s. Both offer a minimum read speed of 5 MB/s. The xD Type M cards have a faster standard rate of 4.0MB/s for reading and 2.5MB/s for writing.
Anything up to 2gb will work with your camera, either the type M or the type M+ will be fine.
Dec 14, 2008 | Olympus Camedia D-540 Zoom Digital Camera
Card error message during formatting XD picture card
The max card size for the camera is either M or H512mb. Try the following website to locate cards for sale www.oempcworld.com
Nov 11, 2008 | Olympus Camedia C-350 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
512 MB card problem
If the new 512mb xD card has a prefix of "H" or "M" before the 512, it is not compatable with your A330 unless a firmware upgrade is performed on the camera. You can download all the details here http://www.fujifilm.ca/x3720.xml
Sep 20, 2007 | Fuji FinePix A330 Digital Camera
Memory Problem
have you tried formatting the card first within the camera, as it may be corrupt, or try it in a card reader and format that way.
May 18, 2007 | Fuji FinePix A330 Digital Camera
Olympus C-750 Trouble formatting card
have u tried to format the card on the computer??? try to format in a card reader.... and after on the camera. if that doesn´t work... could be the kind of card, there are diferent kinds of xD cards. good luck
Apr 02, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Xd card
According to the Olympus website the olympus c350 series camera will only take up to 512 MB xd cards.
Feb 03, 2007 | Olympus Camedia C-350 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
128 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
