Question about JVC DRM10 DVD Recorder
Darn blue loading light won't stop
I have a JVC Dr M10 dvd recorder that I used to love until the blue loading light got stuck. I got it unstuck a couple of times, however when it was in the middle of recording it locked up on loading again. Any ideas Techman?
Thanks
  • Anonymous Dec 15, 2008
    I'm had it. While I appreciate the fact that JVC is wiling to repair this defective product, I'm tired of having my viewing interrupted every few months. I've already had to send the machine back twice and it's just no longer worth the inconvenience. Hey JVC - if you're listening - make good and give me a new Blue Ray. On second thought - forget it!
The problem with these units is the filter capacitors in the power supply. They should be removed and replaced with 25 v.dc capacitors...total cost for the capacitors £5. If you don't fancy doing the repair your self, perhaps you know of a good friend who can use a soldering iron!
The capacitors are 2200 micro farads radial mounting, 680 and 1200, all should be at least 25v dc working for a reliable recorder. The existing ones are prone to "leaking" and should never have been used...shame on you JVC!
Regards,
John Saunders
Posted on Feb 12, 2009
JVC does indeed have a free "Fix" for this problem . The Georgia repair facility received mine at 10 am on the 13th of August , was shipped on the 15th and it just arrived today at 2:30 pm , the 19th of August . Invoice says some 12 items were replaced including 7 caps and a resistor . Return shipping was pre-paid .
Posted on Aug 19, 2008
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Posted on Mar 31, 2008
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Tip
Jvc dvd vhs burner dr-mv1s and dr-m10 loading continues to flash
if you have a jvc dvd vhs burner dr-mv1s or the dr-m10 with the loading that continues to flash with no control of the unit at all there is the first step to take witch is a master or hard reset. done by holding the stop and power buttons at the same time for 10 or more seconds till it powers of then on again.
if this does not work or has no reaction to the unit at all them repairs will have to be made.
i have scowered the internet for fixes for this issue and have found a few interesting things but nothing concrete at all. but lead me in the correct area of the issue. although jvc was fixing these for free at one time they are no longer servicing them under their "free fix"
the problem with the unit is the power supply and although i found that easily on the web. i could not find what the exact problem was untill i did my own diagnostic testing and found that capasitor c5207 on the power supply board was bad and buldging/leaking. it is a 1500uf 6.5v @85 degrees witch i used a 105degree due to the temp and relating the issue with a bad design flaw. so use the higher temp rating one to insure long lasting use.
don't forget to preform the master/hard reset previously mentioned above and you will be back up and running in no time.
good luck......
on Mar 12, 2010 | Televison & Video
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
The blinking blue light on my JVC DR-M10 will not stop and disabe
Regards,
John Saunders
Dec 22, 2008 | JVC DRM10 DVD Recorder
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
Cooling fan stays on all night
You probably have set up one scart as being connected to 'sat' or sat controlled
(I cannot remember the exact setting)
If you do so, the recorder is controlled by the satreceiver, and is 'on' all the time.
Good luck (my DR M10 broke down yesterday - The drive does not recognise dvd-ram disks anymore :( )
Aug 06, 2008 | JVC DR-MV1S DVD Recorder/VCR
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
No remote control
I have a remote that I would be willing to sell. Model # is RM-SDR009J.
Apr 19, 2008 | JVC DR-M1 DVD Recorder
JVC DR-M10 DVD Recorder not working
Mar 12, 2008 | Televison & Video
JVC DRM10 DVD Recorder Logo
512 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
