Question about Lexmark X2470 All-In-One InkJet Printer
How to install lexmark print cartridge
Hi,just want to know how to change cartridge in lexmark 2400 series? many thanks
Please, Can u tell me how can i get the printer drivers to install.
Posted on Mar 17, 2008
    Genius:
  • 3,587 Answers
Open up the top, the cartridges should center, pull the holders up, remove cartridges..be mindful to clean and re calibrate them after installing new ones.
if you need new drivers you'll find them here
Posted on Mar 11, 2008
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
Paper comes out blank
Please check your ink levels:
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select All-In-One Center 3. Click Maintain/Troubleshoot. 4. Select Device status and ink levels.
If all ink levels are still good, proceed to cleaning the cartridge nozzles.
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select Solution Center. 3. Click Maintenance tab. 4. Select Click to fix horizontal streaks.
Your printer will begin to print, forcing ink through the cartridge nozzles and clean them. Try to print your file again.
Jun 17, 2011 | Lexmark X2470 All-In-One InkJet Printer
I don no how to change lexmark x2470 catridge
Hi! Below is a link to the Lexmark user manual. It explains how to change the cartridge. Just click on the link (or copy and paste it to your browser address bar). You have to have Adobe Acrobat Reader installed on your computer to download the .pdf format file. (free at Adobe.com). If this helps you, then please rate this answer. Thanks! Hal
http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf
Jun 11, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lost instructions
Looks like you have mentioned 2 printers. lexmark series 5300 all in 1 and the x2480. here is a link for the x2470 family which the 2480 is based. http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf
Also here is the attached for the C5300 series mentioned just incase. hope they help. 04a2bc1.jpg
Feb 05, 2009 | Lexmark C533DN InkJet Printer
Will cartridge for x2480 work in 2400 series
What is the number on the cartridge you removed?
Jan 18, 2009 | Lexmark X2470 All-In-One InkJet Printer
How to change lexmark Cartridge
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 2400 all in one printer cartridge error
Good day Sir,
Using the solution center provides help as well as information about the printers status and ink level. To open the solution center click Start - All Programs - Lexmark 2400 series select Sloution Center. The Solution Center consists of six tabs. look for maintenance tab and you will see how to install a print cartridge and how to troubleshoot other ink problems.
have a nice day.
Aug 31, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Installed new ink printer - can't print copies of e-mails. Lexmark 2400 Series. Help!
Have you tried copy and pasting into another program ?
i.e Word-Works Office et,c.
Or try changing the font Colour.
Sometimes Works.
Mike @ Compurepair.
Feb 19, 2008 | Computers & Internet
Printer on but not printing
we have a link on how to fix your own printer through this link(check for search box further down page)
Jan 27, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
131 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
