Centrex plasma tv
Will not start up power ok led on sub power board flashes 3times every 3 seconds can u help
  • 7 more comments
  • njmckmagna Mar 11, 2008
    power has been off for days tv just shut down after leavin off for days tried to turn on again but no start up power light on but no raster have checked ic on main board and all fuses all seem ok could it be a regulator if so could you give me a number if faulty?
    no repair person for plasma tv or lcd in this area. the tv in questin is centrex plasma 42 inch model ctpl42s5 centrex has gone bust so i have no acess to parts except non genuine if i have a nunber the set has a samsung pdp sdi module in it also most of the chassy is samsung parts
    could you not give me a clue to check any particular part for short or failure or if one particular board may have the probulem?
    thank you
    I WORK AT A ELECTRONICS SHOP WHERE WE FIX MICROWAVES CD PLAYERS VIDIOS REMOTE CONTROLERS STANDARD TELEVISIONS BUT WE DO NOT HAVE ACESS TO THE NEW TELEVISION REPAIR CIRCUTS OR REPLACEMENT PARTS SO i tryed to acess some knowlege from this site could you give me a clue to where to look for possiable faults the set is only 18mts old but because the company has shut down i have no where to go to try to fix the problem ?
    THANKS FOR TRYING I GUESS IT WILL GO TO THE DUMP NO GOOD GUESSING IT COST TOO MUCH IN PARTS THANKS AGAIN
    hi oneexpert has tryed to help but no clues yet. tv is a centrex plasma model CTPL42S5 IT HAS A SAMSUNG CHASSY AND PDP SDI MODULE
    HAS POWER BUT HAS NO RASTER COULD YOU HELP
    THE POWER SUB BOARD LED FLASHERS 3TIMES EVERY 3SECONDS
    THE COMPANY CENTREX HAS CLOSED DOWN SO I HAVE NO ACESS TO CIRCUTS COULD YOU GIVE ME SOME AREA TO CHECK FOR POSSIABLE PROBLEM
    THANK YOU
    brand is CENTREX
    MODEL IS CTPL42S5
    TYPE 42INCH PLASMA
  • njmckmagna Mar 12, 2008
    THANKS FOR YOUR HELP IF YOU FIND A FIX PLEASE LET ME KNOW.
    yes. THANKS FOR ALL YOUR HELP
    I WILL TRY A FEW THINGS ON CIRCUT BUT HAVE NO IDEA OF VALUES OF SOME PARTS.
    THANK YOU AND THE TEAM FOR YOUR SUPPORT
    IF I FIX THE PROBLEM I WILL LET YOU KNOW.
    Genius:
  • 1,665 Answers
Hi have nice day!
Posted on Mar 11, 2008
    Genius:
  • 3,587 Answers
That means your control board is really unhappy..can you turn it off, for ten minutes, and see if is still the same?
  • 5 more comments
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    well..do you have a local repair person..these are not exactly the kind that can be done online..and besides, there's no model number you've provided..
  • Patrick Michaels
    ooohhh..this is worse than I thought..that's going to happen more than not, especially in the HDTV world..don't know how else to helpya///
    thankya for using fixya
  • Patrick Michaels
    not without some sort of documentation
  • Patrick Michaels
    well..that does happen...at the end of a products lifecycle..I don't guess in my work, as I'm sure you don't either..
  • Patrick Michaels
    well..chasing after a similar design certainly is an option, but not one that I'd recommend. Of course, you could always draw your own schematic, since it might be the only one that exists, then you can sell it online and make a fortune, eh?
  • Patrick Michaels
    Patrick Michaels Mar 12, 2008
    you know, this is getting desperate..
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    you ought to really decide who helped you the most, and close this premium problem out
SOURCE:
Plasma screen does not come on and power supply board is bad
When the Plasma TV is plugged in, there're a fewindications of normal operation. Knowing this will help usunderstand what's going on with the unit when anabnormality occurs.1.There is a click from the relaysRL402andRL403when they are activated.2.The LED in the Optical Jack inside the DT board turns on for approx. 4seconds.3.Immediately after that, one of the Tuner LEDs (Right) turns on(Solid Red)for approximately 20 seconds.4.The LED in the Optical Jack inside the DT board turns on again for approx.1 second and both LEDs (tuner and optical jack) turn off.5.Then you will hear another click from the relaysRL402andRL403indicating that they are no-longer engaged. (Note: At this time the Tunerand the Optical Jack LED turn off.)5
Feb 06, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Error code 11 flashes model TCP50VT25
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
Hi need code for ancient centrex tv for universal remote help aaaaaaaaaah
Hello
Centrex is not listed with URC04110 universal remote coldes. But you can search and find the code for your device with this remote control. I'm not sure will it work with your old Centrex TV. Anyway try. Wish you the best.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
searching for your code. For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release
SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off.
NOTE: In the search mode, the remote control will send IR codes
from its library to the selected device, starting with the most popular
code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1 through
5, but substitute the appropriate device key for the device you are
searching for.
CHECKING THE CODES
If you have set up the remote control using the Searching For Your Code
procedure, youmay need to find out which four-digit code is operating
your equipment:
For example, to find out which code is operating your TV:
SET.
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3 seconds,
count the LED blinks (e.g., 3 blinks = 3) and write down the number.
NOTE: If a code digit is "0", the LED will not blink.
5. Repeat step 4 threemore times for remaining digits.Use 2 for the
second digit, 3 for the third digit, and 4 for the fourth digit.
6. To check for codes of other devices, repeat steps 1 through 5, but
substitute the appropriate device key for each device you are checking.
OK.
Mar 08, 2011 | One For All URC4110 Remote Control
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma No Video
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Apr 12, 2008 | Sanyo DP42746 42 in. Plasma Television
Centrex plasma tv model ctpl42s5
Centrex plasma tv model ctpl42s5 same problem wont turn on have extended warranty, what can we do.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Ekse
