Question about Philips Magnavox 13MT143S 13" TV
We can't get the dvr/cable box to work with the tv
We can get the cabe to feed directly into the tv, but can't get the dvr/cable box hooked up to the tv....help
  • 476 Answers
Assuming you have connected the DVR/Cable box with a standard co-axial antenna cable, switch on the box and go to the tuning menu on the TV.
Tuning details are in the TV manual. If you don't have the manual, download here:
https://www.p4c.philips.com/files/1/13mt143s/13mt143s_dfu_aen.pdf
When tuning is completed go through the channels to find the cable box. (Note: TV will not tune to the box if it is not switched on when tuning)
If there is still no connection, the DVR/Cable box may need connecting with a composite video cable (red / white / yellow RCA connectors), rather than just a standard co-ax cable.
The connection is at the front of the TV. There is no red connector on this TV so you will have to use an adaptor to connect both left and right (red & white) audio into the white socket. Select AV on the remote control.
Posted on Mar 12, 2008
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
How to hook up from TV to recorder
hi there
there are three cable yellow red and white your yellow
cable is the picture cabe and your red and white cabe is the sound cabe plug the yellow cabe in the yellow input and the white and red in the red and white input @ the back ok you recorder now the some go to the tv set it will work 100% now
Dec 19, 2009 | Samsung DVD-VR357
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
I cannot get dvd feed to tv when I connect my jvc
I work for a cable company that has this exact cable box. in our system we choose not to actvate this option. cable companys go to motorola and give them the exact features that they want the box to perform. most cable companys won't have that feature added mainly 1 due to cost and 2 if you have that type of box it probably has on demand available, so they want you to rent a movie then to play it on dvd.in my opinion straight to the tv is better anyway, the less devices you run the video signal through the less problems you will have . all those ports on the back of the box is standard for the 6412, but are not always actvated.
Feb 21, 2009 | Arris DCT2608
Motorola cable box remote codes
Its not going to work unless it is authorized by the cable company, and has the correct software.
Oct 17, 2008 | Motorola Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Adding additional dvrs
I have directtv, how do I add an additional receiver
Nov 28, 2007 | Cyberhome DVR 1600 DVD Recorder
Philips Magnavox 13MT143S 13" TV Logo
278 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
