Question about Dual XDMR7710 CD Player
Dual XDMR7710 player wont save settings
I saved my FM radio stations and i saved my audio settings. but wen i turn off my car, then turn my car back on to listen to the radio, the settings werent saved.
*but if i jus press the power button to turn the player off and not turn off the car the settings are saved. its jus wen i turn my car off the settings are lost.
PLZ HELP ITS DRIVING ME CRAZY. every time i get in my car i have to keep setting it so pls help me.
    New Friend:
Cut the red and yellow wires and cross them to the opposites and connect again and this will save your cd players memory
Posted on Nov 12, 2009
Well it is the memory constant 12v wire problem, when u changed it u probly blew up a fuse or some thing wich isnt realy good... u need to go see some people at a factory to set a new wire or just repair it... will take 15 minutes if the guy is good ;)
Posted on Nov 09, 2008
  • 31 Answers
Maybe your car radio don't have a memory so when you turn it off your settings gone
Posted on Mar 11, 2008
    Problem Solver:
  • 5 Answers
I just uploaded a full install/user manual. I had that prob. It has 2 "hot" wires. One hot all the time..and another hot only when keyed. I had to look at my Cadillac manual to know which was which
Posted on Jun 10, 2008
Check your 12 volt constant wire it might have a bad or faulty connection
Posted on Apr 28, 2008
SOURCE:
I want to reset my radio to stations that I wasnt
for most car radios, select AM or FM. tune into a station you like.
push and HOLD IN the radio's first selector button on the left for
5 seconds. to test, turn to a different station then push the first
button on the left. if it returns to the station you chose, then repeat
by choosing a new station you like and hold in the second button for 5 seconds. go through all your radio's AM and FM bands and do the same thing. happy listening.
May 04, 2018 | Audio Players & Recorders
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Radio doesnt save any settings.....???? HELP
I could answer this but FIXYA will not allow me to use the language it requires .
Dec 08, 2015 | Car Audio & Video
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
How to save FM radio settings in JVC car stereo
Try this, tune to the desired radio station and holdpress the station number ( 1-6) for a while, it should blink twice to confirm its storage.
Ekamave
Jan 12, 2011 | JVC AM FM CD DET FACE CAR STEREO
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Sansa clip - not able to playlist listen on car radio w/ adapter
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
MEMORY PROBLEM
it sounds like your hot wire and memory wire are crossed you need to place your constant +12v wire to a source which is always hot and your memory wire to your ignition when you turn on your car it all works fine
Dec 13, 2007 | Alpine CDM-7833
Radio recieves only odd frequencies
turn radio off, and press the "audio" botton until clock is displayed. then click it again shortly till you see "FM 100" on the display, press > (side arrow, now it should switch to "FM 50". long press on the "audio" to save and exit. afterwards it should work fine.
Feb 22, 2006 | Pioneer DEH-345 CD Changer
Dual XDMR7710 CD Player Logo
595 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
