Question about HP Compaq nc6320 Notebook
Nope can't do
Im using my boyfriends laptop right now, because i have no internet connection at all, even when we plug it straight from the router it wont read it, or cant find it.
  • Anonymous May 11, 2010
    are you saying the pc boots up ok but the internet is not working???
    Terry
  • 520 Answers
Reinstall software for your router or get wireless card if youre 300ft in range of router (or any unsecured network in range for that matter)
Posted on Mar 24, 2008
    Sergeant:
  • 349 Answers
Change the LAN cable it may be crook,thats the easy bit,
make sure in the Internet Protocol (TCP) Properties setting you have
  • "Obtain an IP address automaticlly" selected &
  • "Obtain DNS server address automatically
hope this is of help to you
good luck
Terry
Posted on Mar 13, 2008
    Genius:
  • 3,587 Answers
Hmmm...ok...so..let's see...your compuer just had some sort of restore function, right? I'd recommend you reinstall the operating system..the hard data will be fine..
Posted on Mar 11, 2008
SOURCE:
Dell inspiron 1525 says limited or no connectivity
Could be an issue with the router. Try resetting the router.
Mar 08, 2017 | Dell Inspiron 1525 Laptop
I have an acer travelmate 212tx. it has an ethernet port in the back but when i try to connect to the internet with a wired connection it says that none can be detected. how do i remedy this?
Hi
If you take you ethernet cable from the back of your laptop and plug straight into your router
that should access the internet immediately
If you are trying to ge a t wireless connection from your router then have you checked that you have enabled the wireless switch on your laptop
im not sure but the switch could be over on the far left of the keyboard probably have a small picture that looks like a mini satellite dish
Mar 29, 2011 | Acer TravelMate 212TX Notebook
My laptop won't connect to the internet via wireless even though it sys it is connected to my wireless router
Need more info.
Do you know what type of wireless security you are using?
The first place to check to see if you are "really" connected is to click start, run, type "ipconfig" (no quotes) and see what IP address you have. If you have anything that starts with 169.xxx.xxx.xxx , you are not really connected.
Mar 01, 2011 | Computers & Internet
My laptop is not connecting to my router although it has no problem conecting to my fathers router so i know there is no problem with the laptop. the message i get after connecting to the internet is there...
Change the physical port in your router to laptop(i mean the ethernet port and also replace with a cross over cable instead of straight through cable)
Oct 15, 2009 | Computers & Internet
Limited connectivity
You have to turned on DHCP in your router settings. i think its under the General TAB if its a linksys router
Feb 03, 2009 | Linksys Wireless-G Broadband Router
Belkin wireless security
plug a laptop straight into the router with a cable. then open an internet browser and type in 192.168.0.1
type in the username and password. the default will be admin for username and password for password. then close the browser and unplug the cable. it might detect wireless internet after a few seconds. if it doesn't, it is possible that you have a PC set up as the internet gateway for the laptops or something, so when you introduce encryption the laptops can't get access. in which case you should go to your wireless icon on the laptop and click that and open the connection list. double click on the wap secured connection and try to connect. it should ask for a username and password, which you have secured the wireless encryption with. enter that and it should connect to the gateway.
dunno if this helps, good luck
chris
[email protected]
Dec 10, 2008 | Belkin (F5D9230-4) Wireless Router...
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Im not getting any singnal on my router
check the cable connections..reset the router..otherwise please contact your service provider
May 01, 2008 | Linksys Wireless-G WRT54G Router
Problem in opening the links !
Do you use a router, or are you connecting the modem straight to the laptop?
Does the modem have multiple plugs for computers to plug into (if so, it is functioning as a router as well.?
Do you have any firewall/internet security software installed?
My guess without the above information would be that it is a problem with your DNS setting. Open "Network Connections" and right click on your "Local area connection" and go to properties. Click on the "Internet Protocol (TCP/IP" entry and click properties. Be sure that it is set up to "Obtain DNS server address automatically"
Nov 13, 2007 | Microsoft Windows Vista Ultimate Edition
Poor signal strength on wireless router? ?
k login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Oct 30, 2007 | Belkin (F5D6230-3) Wireless Router
HP Compaq nc6320 Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
